![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BMW Road Map Europe EVO 2022-1
Compatibility: F20, F21 F22, F23, F87 F30, F31, F34, F80 F32, F33, F36, F82, F83 F06, F12, F13 G11, G12 X3 F25 X4 F26 X5 F15, F85 X6 F16, F86 ![]() Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
Welcome ! Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
Added BMW Road Map Europe EVO 2022-2
Added BMW Road Map Europe EVO 2023-1
Added BMW Road Map Europe EVO 2024-1
Added
Road Map Europe EVO 2024-2
Added
Road Map Europe EVO 2025-1
BMW Road Map Europe EVO: Complete European GPS Cartography for ID4, ID5 & ID6 Head Units
WHAT INSIDE: - BMW Europe EVO 2026.2.7z 1. SYSTEM REQUIREMENTS & MANDATORY PRE-UPDATE CHECKS - Multimedia (Head Unit) Type: Exclusively for BMW and MINI vehicles equipped with NBT EVO hardware (including ID4, ID5, and ID6 interfaces) — typically Navigation System Professional (Option S609A) with a widescreen display or Navigation Plus. - Mandatory iDrive Menu Check: Before downloading, open your vehicle's navigation menu (Navigation -> Options -> Navigation System Version) and verify that the current map string explicitly displays the word EVO. - Incompatibility Warning: EVO series maps are strictly incompatible with older NBT systems (require NEXT maps), CIC (PREMIUM maps), EntryNav (ROUTE maps), basic EntryNav2 systems (WAY maps), CHAMP2 (MOVE maps), and newer MGU head units (LIVE and JOY maps). - USB Drive & 20-Digit FSC Activation Code: Installation requires a 64 GB USB flash drive formatted in FAT32 or exFAT. Unless your head unit already has an active Lifetime FSC installed, the system will prompt for a VIN-specific 20-digit FSC Activation Code when starting the update. Please note: this archive contains strictly the map database files only (no FSC activation codes are included). SUPPORTED BMW & MINI MODELS (NBT EVO SYSTEM) NBT EVO head units were factory-installed across the following models (approximately from 2015–2016 to 2019–2020, prior to the transition to MGU): - 1 Series: F20, F21 - 2 Series: F22, F23, F87 (M2) - 3 Series: F30, F31, F34 (GT), F80 (M3) - 4 Series: F32, F33, F36 (Gran Coupe), F82 / F83 (M4) - 5 Series: G30, G31, F90 (M5) — early models before 2019 - 6 Series: F06, F12, F13, G32 (GT) — before 2019 - 7 Series: G11, G12 — until 2019 - X1 / X2: F48 / F39 (in top Navigation Plus trim levels) - X3 / X4: F25, F26 (late models), G01, G02 (early models until 2019) - X5 / X6: F15, F85, F16, F86 - i-Series: i3 (I01), i8 (I12) - MINI: Compatible F-Series models equipped with NBT EVO navigation. 2. PACK FEATURES - Up-to-date 2026.2 cartographic data covering road networks, highways, and regional routes across Europe. - Updated highway interchanges, roundabouts, speed limit information, and lane guidance for metropolitan areas. - Expanded Points of Interest (POI) database including fuel stations, EV charging points, service centers, hotels, and local directories. DESCRIPTION: BMW Road Map Europe EVO 2026.2 is an official cartographic database release (not a standalone PC program) designed to update the factory-installed navigation system in compatible BMW and MINI vehicles equipped with NBT EVO multimedia systems (iDrive 4, 5, and 6). ![]() Need it? Push button Thanks, PM for pass | or by email right now.
The file is here
| Fsc Road Map Europe BMW | Scorpium59 | Vente, Achat, Echange | 3 | 02/07/2022 21h14 |
| BMW Road Map Europe (les dernieres versions) | Scorpium59 | BMW, Mini, Rolls-Royce | 25 | 12/04/2021 02h19 |
| BMW Road Map Europe NEXT 2018-1 | Nyckos | BMW, Mini, Rolls-Royce | 0 | 05/03/2018 20h49 |
| BMW Road Map Europe Professional CCC 2018 | Nyckos | BMW, Mini, Rolls-Royce | 0 | 05/03/2018 20h46 |
| Road Map Europe Evo 2018-1 | Nyckos | BMW, Mini, Rolls-Royce | 0 | 05/03/2018 20h43 |
