Vieux 30/01/2022, 22h46   #1
kamsoft
Avatar de kamsoft
kamsoft is just really nicekamsoft is just really nicekamsoft is just really nicekamsoft is just really nice
Par défaut immo off c3 iaw48p2.7E
Salut , jecherche un off pour c3 iaw48p2.7E ecu org hs et flash perdu .
j'ai un 48p2.78 si je peut avoir un dump qui fera l'affaire.
Chaque jour est une nouvelle opportunité
kamsoft est déconnecté   Réponse avec citation
Vieux 31/01/2022, 10h25   #2
yahiadiag
Avatar de yahiadiag
yahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond repute
Envoyé par kamsoft Voir le message
salut salam
jai la flash IAW 48P2.78 OFF
HW9643707380
SW9644925480
yahiadiag est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to yahiadiag For This Useful Post:
kamsoft (31/01/2022), mcmomo (31/01/2022)
Vieux 31/01/2022, 11h13   #3
kamsoft
Avatar de kamsoft
Bonjour ,c'est un 206 ca marche pas avec c3 pbl (clin ,ventil,batt..)
The Following User Says Thank You to kamsoft For This Useful Post:
yahiadiag (31/01/2022)
Vieux 31/01/2022, 15h14   #4
yahiadiag
Avatar de yahiadiag
re voici la flash
Type de fichier : rar iaw48P2.7E C3.rar (126,1 Ko, 33 affichages)
Vieux 31/01/2022, 16h26   #5
kamsoft
Avatar de kamsoft
Salut ca na pas marcher ,f3 et f4 debrancher puis rebrancher
flasher sur ecu hw 16.623004 hw 9645989480 sw16.594.014
Vieux 31/01/2022, 17h44   #6
mcmomo
Avatar de mcmomo
Pouvoir de réputation: 26
mcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant future
Par défaut off
tu peux tester
Type de fichier : rar 29F400_immo_off.rar (119,7 Ko, 18 affichages)
mcmomo est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to mcmomo For This Useful Post:
kamsoft (31/01/2022), yahiadiag (31/01/2022)
Vieux 31/01/2022, 21h37   #7
kamsoft
Avatar de kamsoft
salut,toujour rien la pompe ess ne sarrette pas a la mise sous apc et pas de start
es possible avec ktag ? je commence a avoir ..... pour la soudure.
mcmomo (31/01/2022)
Vieux 31/01/2022, 23h00   #8
kamsoft
Avatar de kamsoft
J'ai un autre ecu bosch M744 qui fait demarrer au quart de tour ,mai en mode echo
ya t'il un dump compatible avec ?
Vieux 01/02/2022, 21h43   #9
kamsoft
Avatar de kamsoft
Salut j'ai prog 2 calculo en off (iaw48p2) et essayer sur 206, les deux fonctionne ,mais sur c3 pas de demarrage !!!
quel est la mielleur solution a faire ?
- recupere s2000 + vierge
- lire pin du bsi
-telecodage
es bien ca ?
un coude de pouce les amis
Vieux 02/02/2022, 09h35   #10
yann3
Avatar de yann3
Pouvoir de réputation: 76
je ne pige pas ton post
tu cherche off iaw48p2.7E
tu essais avec s2000,puis ME 7.4.4
c'est quoi se delire??
ta pas essayé edc15c2 par ex
http://www.armoreprog.fr
Jock66 (04/02/2022)
Vieux 03/02/2022, 23h15   #11
kamsoft
Avatar de kamsoft
si tu peut fait le ta pas envie d'aidé les autre ,ta meme pas la politessse pour dire bonjour.
Vieux 04/02/2022, 15h31   #12
yann3
Avatar de yann3
j'ai pas saisie ce que tu as ecrit
reconnait que ton post est un peut bizard tu demande pour un ecu et ca devire sur 2 autre ecu et aucun de la meme race ou marque pour le meme vehicule ??
developpe et instruit un peut mieux ton post,si tu veut des reponses qui tienne la route .
et puis au niveau aide,je n'est plus rien a prouver,les membres on leur opinion sur le sujet
Vieux 04/02/2022, 20h13   #13
kamsoft
Avatar de kamsoft
Salut et execusé mon agricivité ,j'ai était un peut fatigué ne fait pas trés attention de ce que j'ai dit ,le faite j'ai pas trouvé un ecu dans la meme ref , je voulez tout simplement savoir ce qui peut le remplacer et comment l'adapté soit en off ou vierge ,et en tout j'ai pas d'expérience en ecus et j'apprent toujour.
Vieux 05/02/2022, 11h01   #14
yann3
Avatar de yann3
ce n'est pas un soucis
il te faut le meme ecu pour avoir deja les memes pinout et surtout la meme structure de soft
kamsoft (05/02/2022)
immo off iaw48P2.80 DIAGSYSTEM25 Immobilizer dumps/solutions 9 10/11/2022 14h09
immo off IAW48P2.74 kamsoft Immobilizer dumps/solutions 8 03/06/2020 23h31
immo off iaw48p2.7E formator2 Immobilizer dumps/solutions 1 14/10/2019 18h18
immo off iaw48P2.76 rrguillaume Immobilizer dumps/solutions 9 05/06/2018 16h50
immo off 206 iaw48p2.78 auto perf Immobilizer dumps/solutions 3 28/09/2016 17h59
Fuseau horaire GMT +1. Il est actuellement 11h37.
