| ABS, ESP, DSC tous ce qui concenent ces systèmes et leur réparation. |
I have came across a Range rover Evoque 2020 D180 HSE where the EPS system (Electric Power Steering) failed to perform and shut off completely, the steering wheel is heavy so heavy.
The complete shut off came after the car hit sudden bumps and holes at high speed. No DTC showing up when scanning the car. |
#2 | |
Pouvoir de réputation: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Hi you have breaks the electric motor Behind the car or disconnect the wire on the shocks J'entends et j'oublie, je vois et je me souviens, je fais et je comprends. |
| Demontage EGR Range rover evoque | zefirin | Mécanique générale | 1 | 06/11/2018 18h28 |
| Diag range rover evoque | ECU diag | Ford, Mazda, Land Rover, Jeep, Jaguar | 10 | 15/12/2016 00h15 |
| problème capteur de pression de freinage sur "Range Rover Evoque SD4 " | aza | Ford, Mazda, Land Rover, Jeep, Jaguar | 2 | 20/03/2016 14h02 |
| range rover evoque 2012 | dreambox | Ford, Mazda, Land Rover, Jeep, Jaguar | 2 | 07/05/2014 19h53 |
| Range rever evoque km | moghit2 | Tableau de bord (Dashboard) | 9 | 05/03/2014 19h52 |
