Pouvoir de réputation: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
bonjour a tous
je partage MaxiECU2 full pour windows 7/8/10 en 32 bits avec tuto d installation.interface mpm-com/obdlink/elm327/opcom ect.... https://mega.nz/folder/Sk4gmYiK
:yo: |
| The Following 90 Users Say Thank You to riri333 For This Useful Post: | Acidited (11/10/2022), adiago (17/11/2020), akasa67 (27/12/2020), Anonin88 (22/11/2020), audi39 (26/03/2023), autodiagauto (17/11/2020), BAB62 (28/12/2020), bbert90 (10/02/2021), beckouse (17/12/2021), bel27 (27/12/2020), ben311 (04/01/2025), benhedi70 (10/02/2021), benouzi (05/11/2021), bigfoot1702 (29/07/2021), bino78 (26/08/2022), Borokrom33 (15/02/2023), boukrama (17/11/2020), Brice59 (18/11/2020), carto (27/12/2020), csj0oe (23/12/2022), culbuto (30/07/2021), curtis50 (29/05/2023), dede83 (05/04/2021), denis994 (28/02/2021), DIAGSYSTEM25 (31/07/2026), djacou (18/11/2020), djamel30 (30/07/2021), duroi (28/12/2020), ElTurco (26/02/2021), FABRICE56 (17/11/2020), Fargo (03/10/2024), fario12 (17/03/2022), fefjp (22/07/2021), foulques (17/11/2020), fred9545 (12/02/2021), gervet95 (24/04/2024), goemyo (10/03/2021), gpv (17/10/2022), Helios (30/07/2026), his95 (29/11/2020), Honda (28/12/2020), jalel31 (26/11/2020), Jc92 (04/07/2021), Jojo55 (20/06/2022), jtuning (18/01/2022), Julien59820 (01/01/2025), kevin22 (27/07/2021), khyentse (01/01/2021), kis2a (04/06/2024), livediag (26/08/2026), loupo76 (28/01/2026), manudiag (26/10/2022), mecano13 (27/12/2020), Med1387 (10/02/2021), michel13 (28/12/2020), multi290 (27/12/2020), nad97799585 (24/03/2023), nain_connu (27/12/2020), nasisamy (11/07/2022), nastradini (17/11/2020), pcvsfr (05/04/2021), PixL (21/08/2022), pp08 (29/12/2020), progdebutant (17/11/2020), progreurLvl1 (23/07/2023), raimond52 (09/12/2020), reda75 (17/11/2020), ronan4982 (27/07/2021), rosaire974 (19/11/2020), salimalouane (10/02/2023), samy.one (29/12/2020), Sebos (28/07/2021), shami (02/08/2021), SLYsg1 (03/06/2022), taxi5114 (12/08/2023), tonton07 (04/01/2026), transitforum (11/02/2021), Truc (10/02/2021), tursio46 (14/01/2025), verbatime (17/11/2020), vortex (21/11/2020), xdols (18/11/2020), yahiadiag (27/12/2020), yoan6446 (28/08/2024), yoyomartin2003 (18/11/2020), zebulons (28/12/2020), zefirin (18/11/2020) |
bonjour akasa67 tout va bien de mon coté en espérant que de ton coté aussi
j utilise un elm 327 que j ai utilisé sur un scénic 1 phase deux ,un peu limité donne les valeurs en direct et c est tout. avec la sonde oblinck sx pas de réponse pour le scénic mais sur bmw e46 pas de problème , avec elm 327 aucune connection sur e46. il faut que je fasse le test sur 407et mon véhicule e39 pour voir si cela passe bonne journée
:yo: |
Ben écoute sa va la santé je me refais merci temps mieux si tous va bien de ton coter, ben justement j'ai essayer sur table avec odblink sx un sirius 32 pas de com et j'ai essayer 2 sid psa idem pas de com sur psa apparement faudrait un câble entre la sonde et le véhicule
| The Following User Says Thank You to akasa67 For This Useful Post: | jojolabricole (31/01/2025) |
bonsoir akasa67 et bonsoir a tous
j ai fait un test sur 407 de 2006 1l6 hdi sonde oblink sx :aucune communication et avec elm 327 communication dans calculateur moteur seulement , paramètre en temps réel et génération forcée, changement filtre particule,et remise a zéro cerine bonne soirée a tous
:yo: Dernière modification par riri333 ; 28/12/2020 à 21h28. |
Pouvoir de réputation: 10 ![]() ![]() |
J ai la mpm com, ça devrait fonctionner mais à dernière mise à jour, chez maxi ecu il associe le soft au S/N du boîtier [emoji1787][emoji1787]..
Ils sentent le vent tourner [emoji6] Envoyé de mon Redmi Note 8 Pro en utilisant Tapatalk
un petit thanks, please :) |
| The Following 2 Users Say Thank You to BAB62 For This Useful Post: | jojolabricole (31/01/2025), riri333 (28/12/2020) |
Pouvoir de réputation: 36 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
soft installé mais aucune communication avec aucun calculateur, ni avec elm327, ni avec la sonde obdlink sx les 2 sondes sont bien reconnu dans les paramètres du logiciel a voir... Dernière modification par pp08 ; 29/12/2020 à 13h26. |
bonjour a tous
les membres ayant une sonde mpm com pourraient ils faire un retour afin de savoir si cela marche.comme je l ais dit quelques post plus haut j ai réussi a faire marcher mais que les données en temps réelle et sur certain véhicule. merci a eux pour leur retour. bonne journée a tous
:yo: |
| The Following User Says Thank You to riri333 For This Useful Post: | Med1387 (11/02/2021) |
Pouvoir de réputation: 25 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
fonctionne très bien avec MPM com interface
| The Following 4 Users Say Thank You to nastradini For This Useful Post: |
#9 | |
Pouvoir de réputation: 9 ![]() ![]() |
| The Following User Says Thank You to Ludo80 For This Useful Post: | riri333 (12/02/2021) |
#10 |
Bonsoir riri333
Merci pour ce partage. J'ai effectué le test avec avec l'interface MPM com en USB sur une TOYOTA 2014, à chaque tentative j'ai ce message refus de connexion aux calculateurs... Par contre avec le test des actuateurs j'ai activé les ventilateurs. Je tenterai de nouveau le test un peu plus tard après vérification. Cordialement |
| The Following User Says Thank You to transitforum For This Useful Post: | riri333 (12/02/2021) |
#11 | |
testé avec obdlink sx sur renault master 3 : ca dialogue sur fiat grande punto : aucun dialogue |
#12 |
![]() Date d'inscription: avril 2023
merci pour le partage
quelqu'un a test avec un vGATE VLinker FS ??? une version .0 est sortie , mais aucun leak pour le moment ? a+++ |
#13 |
ps: Version 3.0 sortie , mais en full marque presque 600€
ces un autocom amélioré ou ca peut remplacer , diagbox , canclip , xentry ..... etc etc ? car si fais le job des vci des marque ces pas si cher au final aussi non , mieux vos chaque vci des chaque marque ? |
#14 |
Merci pour le partage mais quelq'un l'a déjà essayé sur une mercedes c220 w203 ?
---------- Post added at 01h36 ---------- Previous post was at 01h30 ---------- Bonjour pouvez vous me fournir la clef de déchiffrement svp afin que je puisse accéder au code erreur srs merci |
#15 |
Pouvoir de réputation: 5 ![]() ![]() |
Salut, il faut revoir le réglement Loupo76.
| ODIS 4.4.10 Full Full Package | omarzoro | VAS5054, VCDS, ODIS | 47 | 01/05/2019 15h29 |
| KTAG v2.23 fw7.020 FULL +KESS V5.017 FULL | abdel59100 | Vente, Achat, Echange | 6 | 21/06/2017 01h38 |
| Promotion DP3 full + full air bags + mise a jour gratuite pendant 6 mois | autoprog66 | Vente, Achat, Echange | 18 | 07/08/2014 20h50 |
| difference entre galetto V2 full et full master | mustauto | Programmateur de composant (flasher) | 4 | 28/10/2012 12h58 |
