Vieux 23/06/2020, 12h45   #1
momoh-93
Avatar de momoh-93
momoh-93 is a name known to allmomoh-93 is a name known to allmomoh-93 is a name known to allmomoh-93 is a name known to allmomoh-93 is a name known to allmomoh-93 is a name known to all
Par défaut Dde4
Yop la compagnie,
J'aurais besoin d'un coup de main pour une lecture sur un dde4 sur un Landrover en boot avec Fgtech
Si du monde l'as déjà fait
---------- Post added at 12h45 ---------- Previous post was at 12h44 ----------
J'ai besoin de faire un clone précisément
"Le travail est la moitié de la santé"
momoh-93 est déconnecté   Réponse avec citation
Vieux 23/06/2020, 14h47   #2
ElTurco
Avatar de ElTurco
ElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond repute
Salut frère Mohamed
d'après l'avis des utilisateurs Fgtech 0475 Galletto V54 :
5.) Land Rover 2.0 td4 diesel DDE4 Bosch read / write via OBD2
Apparemment c'est fait en OBD2 directement, il faudrait avoir la version 0475 du Galletto.
Source:
http://blog.autoobdtool.fr/2019/07/1...s-des-clients/
"Ne pas faire aux autres ce que l'on ne veux pas que les autres te face"
ElTurco est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to ElTurco For This Useful Post:
autodiagauto (25/06/2020), momoh-93 (23/06/2020), rapou30 (23/06/2020)
Vieux 23/06/2020, 15h10   #3
rapou30
Avatar de rapou30
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonjour, je viens de controler sur mon Galletto clone V54 version 0475 et ca me donne lecture et ecriture ok par obd pour un freelander 2.0l DDE4 .
En boot je ne le trouve pas .
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following User Says Thank You to rapou30 For This Useful Post:
Vieux 23/06/2020, 15h34   #4
momoh-93
Avatar de momoh-93
Salam el turco, Yop Rapou
Si j'ai trouvé la méthode pour le lire en boot , c'est une galère mais sa se lit.
Du coup maintenant se pose le truc de comment le cloner ce calculo
Carto de l'ancien mis sur le nouveau calculo simplement ? Ou il faut echanger la 5p08 également ?
The Following User Says Thank You to momoh-93 For This Useful Post:
Vieux 23/06/2020, 16h56   #5
rapou30
Avatar de rapou30
Bonjour, je ne connais pas ce calculo mais je ferai un clone de l'eep via un lecteur d'eep car il y a peut etre le pin ou des codes qui empêcheraient le bon fonctionnement .
Le SW est le meme que l'ori ?
Vieux 23/06/2020, 17h27   #6
momoh-93
Avatar de momoh-93
Oui ils sont exactement identiques
Éventuellement un swap eep des deux epp dans le nouveau ?
Vieux 23/06/2020, 20h33   #7
rapou30
Avatar de rapou30
Oui si tu es équipé c'est bien , en plus une fois déssoudé tu peut les sauvegarder.
Vieux 25/06/2020, 18h00   #8
momoh-93
Avatar de momoh-93
Bon les news sont pas top
J'ai fait le swap eep 29F et 5p08 ,impossible de faire une synchro . Le véhicule ne demarre pas.
Et avec l'ancien calculo il démarrait
Quand je regarde dans les info véhicule il y a la ligne AIF : FFFF
Savez vous a quoi cela correspond ?
Et les deux messages qui restent sont :
Echec message CAN
Panne d'antidémarrage EWS
Avez vous une piste les gars ? Je suis un peu embêter
Vieux 25/06/2020, 21h16   #9
momoh-93
Avatar de momoh-93
Info peut être importante le démarreur tourne .
Au départ je n'avais aucun code défaut, j'ai débranché la batterie quelques minutes, puis rebranché et c'est la que sont apparu les 2 défauts .... Si sa peux aider et m'aider
Vieux 26/06/2020, 09h19   #10
rapou30
Avatar de rapou30
Bonjour, il est possible que ça vienne d'une soudure.
Vieux 26/06/2020, 14h36   #11
momoh-93
Avatar de momoh-93
je les ai toutes vérifié, par contre j'ai remarqué que la 29f chauffe un peu
Vieux 27/06/2020, 18h39   #12
momoh-93
Avatar de momoh-93
pour vous donner des news
Le module Ews me bloque pour la synchro , impossible de dialoguer avec ,
Quand je débranche son fusible de 5a le demarreur ne se lance plus, du coup c'est bizard il fait son taf mais ne veux pas se synchroniser ....
rapou30 (03/07/2020)
Vieux 27/06/2020, 23h10   #13
momoh-93
Avatar de momoh-93
je fait un monologue mais c'est pour faire avancer le bazar
Les clefs sont bien reconnu par EWS, je peux les resynchroniser sans probleme, et voir si elles sont autoriser a démarrer . Elles le sont .
J'ai presque plus de cheveux
Vieux 27/06/2020, 23h24   #14
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 66
Envoyé par momoh-93 Voir le message
Salam Momoh. ou Yul Brynner [emoji23]
si plus de cheveux c’est la boule de billard qui gagne
Tant mieux pour toi tu a résolu
momoh-93 (27/06/2020)
Vieux 27/06/2020, 23h29   #15
momoh-93
Avatar de momoh-93
Salam Pocoyo !
Si seulement elle démarrais pas grave pour les cheveux sa repousse
Mais elle ne démarre pas
POCOYO (27/06/2020)
Ori Bmw 330d/530d dde4.0 patator03 Fichiers d'origine, carto, dump, fullbackup 2 14/06/2017 09h53
Trouver ISN Bmw 330d e46 dde4.0 patator03 BMW, Mini, Rolls-Royce 3 02/05/2017 17h26
[BMW] Need ISN code from DDE4 ecu dumps doud77 Transponder, code pin 1 23/09/2016 15h58
Code de panne EWS3 ou DDE4 HS kyclon programmation & synchronisation de clé 14 09/11/2015 20h14
[RECH] Schema électrique BOSCH DDE4.0 BMW aymeric Pinout calculateurs et bootmode 2 25/01/2012 09h14
Fuseau horaire GMT +1. Il est actuellement 22h50.
