Vieux 26/03/2020, 12h57   #16
Mook31
Avatar de Mook31
Salut, je suis étonné la 2.23 est plutôt stable pourtant.
Je vais t’envoyer le soft, télécharge le et installe le après avoir bien desinstaller et passer Ccleaner.
Ça te permettra d’écarter un problème Hardware sur ton Ktag plus récent.
---------- Post added at 12h57 ---------- Previous post was at 12h54 ----------
https://mega.nz/#!Mnhh0YCb!zYXmjbOqM...mDEGi2Gb-hKiGM
Voilà pour toi, installe proprement, retente une lecture et fais un retour.
The Following 4 Users Say Thank You to Mook31 For This Useful Post:
calixo22 (26/03/2020), ElTurco (28/06/2021), mahfoud lichani (26/03/2020), Myahmedidri (26/03/2020)
Vieux 26/03/2020, 13h01   #17
Tof02770
Avatar de Tof02770
Tof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to behold
Slt l'ami et ta fais même bronchement avec résistance ??????!!!!!!!!!!
Tof02770 est déconnecté   Réponse avec citation
The Following User Says Thank You to Tof02770 For This Useful Post:
Vieux 26/03/2020, 14h04   #18
Myahmedidri
Avatar de Myahmedidri
Pouvoir de réputation: 9
Myahmedidri has a spectacular aura aboutMyahmedidri has a spectacular aura about
Envoyé par Tof02770 Voir le message
Sans resistance
Envoyé de mon Redmi Note 7 en utilisant Tapatalk
Myahmedidri est déconnecté   Réponse avec citation
The Following User Says Thank You to Myahmedidri For This Useful Post:
Tof02770 (26/03/2020)
Vieux 26/03/2020, 14h14   #19
bel27
Avatar de bel27
bel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond repute
cest sa les clones cest toi et ta chance demande le retour de l objet si tu es dans les delais
ton ktag 2.23 pcb vert ?
bel27 est déconnecté   Réponse avec citation
Vieux 26/03/2020, 14h58   #20
SAM0211
Avatar de SAM0211
SAM0211 is an unknown quantity at this point
J’ai fait la lecture avec k tag sans résistance ça marche nickel
SAM0211 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to SAM0211 For This Useful Post:
bel27 (26/03/2020), ElTurco (28/06/2021)
Vieux 26/03/2020, 15h16   #21
Myahmedidri
Envoyé par bel27 Voir le message
Ktag pcb rouge sw 2.23 hw 7.020
Vieux 26/03/2020, 16h23   #22
Myahmedidri
Envoyé par Mook31 Voir le message
Ça n'a pas marché tjrs se bloque a 75%
Vieux 26/03/2020, 16h42   #23
bel27
Avatar de bel27
pcb rouge meilleur que le vert faut ce rendre a l évidence pour ton clone 2.23
ta pas tirer le bon numero
The Following User Says Thank You to bel27 For This Useful Post:
Mook31 (26/03/2020)
Vieux 26/03/2020, 16h58   #24
Mook31
Avatar de Mook31
Envoyé par Myahmedidri Voir le message
Ou as lu d’autres ecu avec ce Ktag ? Ça semble être un problème matériel à mon humble avis.
The Following User Says Thank You to Mook31 For This Useful Post:
Vieux 26/03/2020, 17h39   #25
Myahmedidri
J'ai lu ce soir dme bmw msv70 avec succès.mais sid807evo eeprom se lis bien mpc se bloque a 75% de lecture.
Vieux 26/03/2020, 17h56   #26
Mook31
Avatar de Mook31
Il faudrait que tu lise un ecu avec un mpc se rapprochant (1784,1797 etc...).
Mais comme dit notre ami bel27, il y a des chances que tu sois tombé sur un Ktag défectueux.
The Following 2 Users Say Thank You to Mook31 For This Useful Post:
bel27 (27/03/2020), Myahmedidri (26/03/2020)
Vieux 18/04/2020, 17h04   #27
Myahmedidri
Salut j'ai testé aujourd'hui un edc 17 bosch avec un mpc 1797 ça pass bien mais avec seimens le problème persiste.
Merci pour votre soutien,il reste de changer la carte sd .
Vieux 08/05/2020, 18h56   #28
BILAUTO
Avatar de BILAUTO
Pouvoir de réputation: 59
SLT J4AI UN DEFPA ET EGR OFF a faire sur une 207 HDI 1.6 ECU SID807
J'ai un KTAG Clone Version 7.020 en 2.23 mais je ne trouve pas le SID807 quand je sélectionne le véhicule 207
pourtant dans partner il est bien.
Que faire ?
Vieux 08/05/2020, 19h16   #29
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 88
Slt
C est le meme protocole.
The Following 3 Users Say Thank You to ggvaniou For This Useful Post:
BILAUTO (08/05/2020), rapou30 (04/07/2020), Y.B tec (08/05/2020)
Vieux 08/05/2020, 19h48   #30
BILAUTO
Avatar de BILAUTO
VOICI LES FICHIERS
Qui peut me faire un EGR OFF et FAP OFF
j'ai fais un fap off avec DPF REMOVER mais pas encore testé. j'ai joint les fichiers
merci grandement les amis
Type de fichier : rar SID 807 207 KALEK.rar (1,80 Mo, 14 affichages)
The Following 3 Users Say Thank You to BILAUTO For This Useful Post:
ElTurco (28/06/2021), rapou30 (04/07/2020), WJon (21/05/2021)
Lecture ecu VW T5 OBD Mook31 Réparation & Programmation 10 19/11/2019 13h21
lecture PCR 2.1 Adrien13 Réparation & Programmation 4 11/07/2019 15h20
lecture bsi 208 soustourou Electronique 1 13/03/2019 22h38
Lecture BDM YUMBO Programmateur de composant (flasher) 0 11/01/2015 17h38
lecture nec beonce Programmateur de composant (flasher) 0 05/03/2012 11h56
Fuseau horaire GMT +1. Il est actuellement 07h11.
