Hi friends
I have a Renault Master, 2.5 dci, 100 cv, 2003 I need immo off for the ECU please BOSCH 0 281 011 940 95P08 eeprom Best Regards hugopinho |
Slt l ami voilà ce qui faut faire
https://youtu.be/pNqBTzp7MVc
| The Following 3 Users Say Thank You to akasa67 For This Useful Post: |
Hi
I've already seen the tutorial https://youtu.be/pNqBTzp7MVc and understood all the steps. my question is if the switch is needed and if it has to be turned on every time the car is started. it is not enough to cut the plug anyone can help me Regards hugopinho |
| The Following User Says Thank You to hugopinho For This Useful Post: | duroi (10/03/2024) |
You can do the off on the table and shunt the can on the uch, you don't need the button every time.
you r ecu is edc 15c3?
The problem on these is usually the key read 93c46 in immo unit and use gambit or zed bull to produce transponder from dump
Immo off on this renault master was done
I made 95P08 virgin and solder renault emulator inside the ecu,cut the immo line wire conector A (the small one) pin G2, put the ecu back on the car, ignition on for 30sec.,then off for 30seconds (repead this 5 times),then start the car ---------- Post added at 11:25 PM ---------- Previous post was at 11:18 PM ---------- read 93c66 memory from uch and use RenaultPinExtractor to find the code and rewrite the keys |
#10 |
virgin file and photo emulator
#11 |
Tu lui a mise une couverture sur l émulateur lol non sa n'a rien à voir lui et en can....
#12 |
Bonjour j'ai exactement le même soucis sur un master 2.5 EDC15C13 la solution avec émulateur by JULIE on doit systématiquement toucher les câbles avant démarrage ou seulement la première fois pour l'apprentissage du vin dans l'émulateur ? Aucune idée de comment sa fonctionne leur systéme de devoir couper la linhe CAN L et CAN H
#13 |
il faut mettre un switch sur canL
Ca arrive regulierement de falloir couper le canpour demarrer
http://www.armoreprog.fr |
#14 |
![]() Date d'inscription: septembre 2013
Interrupteur obligatoire oui. La joie des Renault en immo.
| immo off renault master | dasauto | Immobilizer dumps/solutions | 11 | 14/04/2018 11h12 |
| IMMO OFF renault master | DIAGSYSTEM25 | Immobilizer dumps/solutions | 12 | 12/08/2015 16h53 |
| Immo renault master | CSYSTEME | Immobilizer dumps/solutions | 0 | 05/09/2012 16h02 |
| immo off Renault Master DCI 1.9 | slv | Immobilizer dumps/solutions | 9 | 08/11/2009 01h07 |
| renault master 2006 immo off | mehdifree | Immobilizer dumps/solutions | 2 | 22/07/2009 16h27 |
