Vieux 11/06/2018, 08h42   #1
Roturbo
Avatar de Roturbo
Roturbo has a spectacular aura aboutRoturbo has a spectacular aura aboutRoturbo has a spectacular aura about
Par défaut -Actia-XS-Passthru-64bit-Driver- 1Gen VCI-
64bit drivers for Actia Passthru+ XS (1 gen yellow & blue interface).
Maybe the first release on the World Wide Web, the old VC1 from Actia
IS working as J2534 on 64bit Windows 7. :wink:
You are the only one to blame if something goes wrong, so first make backup of important data,
or test this instructions first inside a Virtual Machine or any testing PC.
Remember, i don´t have responsibility of any kind, any problem you solve it,
i have test it and it works, and it is free for you to test,, only IF YOU WANT.
Instructions (please follow the more detailed installation inside RAR file)..
No need to disable Anti_Virus, and i strong advise you to do a virus scan on this folder.
This modified drivers are only to work as PassThru under 64bit,
it will not work with Actia Multidiag software, because the interface
is not recognized, for Multi-Diag Actia-Connect use a 32bit OS.
1º install --I+ME-Actia-PassThru-XS-Driverpack-xx1--
2º install --I+ME-Actia-PassThru-XS-Driverpack-xx2--
Go to device manager and chose update drivers for Passthru+ XS,
chose ""Browse my computer for driver software""
Than click "NEXT" it will give you driver warning, press "Yes",,
it will open a red windows security about the publisher, just
click ""Install this driver software anyway""
It will confirm Updated Driver software success, next remove power from
the interface, power it up again, if asking again for drivers just repeat
one more time the process,, if you see the serial number on the driver name ,
power down, power up install driver,and is done.
If this software "I+ME-Actia-PassThru-XS-Driverpack-xx1" is not installed than
your interface will not be listed as a PassThru interface, so you must install it.
This way you will have the 1Gen interface (blue & yellow) listed as available
for any software working with passthru (under 64bit), just select it and start working.
Tested several times in Windows 7 64bit, communication confirmed with
Forscan, Xentry, etc.
Probably there is easy ways to do the same, but this was the fastest i have
discovered by myself, and works without problems.
Also i have Vas5054 working on 64Bit, but is on testing, the xentry
picture show it listed on the available Passthru interfaces (last picture).
You can download the Pictures-mega-link if this ones vanish (no pass),
for the Mega-link.rar PASSWORD you need to follow the next instructions.
First you press and than ,, next send PM with title
-64bit drivers for Actia Passthru+ XS-password-
And you will get BY PM the password for Megalink.
DO NOT ASK THE PASSWORD ON THE BOARD.
Password Pm= Thanks+Rep
ROTURBO.
Type de fichier : txt Pictures.mega-link.txt (70 octets, 129 affichages)
Type de fichier : rar Mega-Link-t.rar (462 octets, 166 affichages)
Roturbo est déconnecté   Réponse avec citation
The Following 46 Users Say Thank You to Roturbo For This Useful Post:
adjee (18/10/2019), alla12h (02/04/2021), allbc (18/07/2020), Amine-TE (18/08/2018), arifcan (19/04/2019), autodiagauto (08/03/2024), azdineadil (19/09/2025), batmob (31/08/2019), Binbin (03/05/2021), boukrama (05/04/2019), brejaud (18/03/2019), curtis50 (19/03/2024), Dsaadi5 (24/11/2024), ElTurco (09/04/2019), Emma (30/08/2021), fedge (19/08/2018), fethidiag (17/03/2019), fot (22/11/2020), fufounet (24/09/2019), jah83 (18/08/2018), jeremy72 (18/08/2018), jovan (11/06/2019), khalil84 (10/12/2022), klif26 (18/03/2019), kronos1981 (28/01/2021), marikette (05/04/2019), megabase (27/11/2023), mou.kili (29/08/2021), mrawzin (30/04/2019), nounou197131 (12/07/2026), omarino (19/08/2018), prinzo57 (24/08/2019), Ralphe62 (11/04/2026), ronan4982 (11/06/2018), salimalouane (04/05/2021), selouan (18/03/2019), tchaqry (16/06/2024), thierry du58 (19/08/2018), Truc (19/08/2018), valvolinas (09/10/2022), vieuxchoub (07/05/2023), vortex (18/03/2019), xboxcristal62 (18/05/2019), yoyomartin2003 (15/06/2018), zenata (18/08/2018)
Vieux 18/08/2018, 13h43   #2
Pouvoir de réputation: 175
après une longue installation de mercedes 2018 et volvo vida 2014
Je cherche le driver 64 bit pour ma vci actia xs passthru (jaune/bleu )
indispensable pour avoir une meilleure communication
merci encore pour votre aide
cdlt
Vieux 18/08/2018, 14h08   #3
BILAUTO
Avatar de BILAUTO
Pouvoir de réputation: 59
Je ne comprends pas tout on peut utiliser l'interface multidiag de chez Action avec d'autres logiciels
The Following 2 Users Say Thank You to BILAUTO For This Useful Post:
Alessiapia14 (18/08/2018), pouettedu76 (18/08/2018)
Vieux 18/08/2018, 14h22   #4
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 69
Envoyé par BILAUTO Voir le message
Bonjour tout le monde,cela attire ma curiosité aussi, Zenata pourrai tu nous expliquer,
Car moi comme BILAUTO, avons le même doute je Pense.
Vieux 18/08/2018, 14h22   #5
oui
il te faut les soft passthru avec :
comme mercedes xentry passtrhu
volvo vida
hds honda
techstream toyata
gds 2 hyundai kia
global tis opel
consult 3 + nissan (je voudrais tester
la version Nissan Consult III+ 73.20 / Programming Data 71.40)
c'est pour sa il me faut le driver 64 bit , mais pour 1er generation actia
The Following 4 Users Say Thank You to zenata For This Useful Post:
Alessiapia14 (18/08/2018), khalil84 (10/12/2022), pouettedu76 (18/08/2018), vortex (05/04/2019)
Vieux 18/08/2018, 14h40   #6
Pouvoir de réputation: 88
salut 32/64 bits ca marchera pareil !
zenata (18/08/2018)
Vieux 18/08/2018, 15h09   #7
Il ne va tres bien avec x86, (32bit).
Le modele qui ne marche pas.
B247 A valid serie was not selected
CLA 118 A valid serie was not selected
A117 Error - 1.59920.1
C205 Error - 1.59920.1
E238 Error - 1.59920.1
E213 Error - 1.59920.1
S222 Error - 1.59920.1
S217 Error - 1.59920.1
X 290 AMG Error - 1.59920.1
CLS 257 Error - 1.59920.1
GLE 167 Error - 1.59920.1
GLC 253 Error - 1.59920.1
En 64bit tout va bien.
Mais en x64 il ne a pas Passthru driver por vas5054 et Actia XS.
http://www.tlemcen-electronic.com/fo...451#post616451
je pense , je suppose , d'apres les dires de Roturbo
reste à tester , merci jeremy pour ta participation
a la discussion , je sais que tu es compétent
klif26 (18/08/2018), pouettedu76 (18/08/2018)
Vieux 19/08/2018, 08h44   #8
salut, c'est vrai qu'avec cette sonde vci1 Actia Passthru+ XS-password ont peut communiquer avec beaucoup de soft.
Y.B tec (05/04/2019)
Vieux 19/08/2018, 10h14   #9
BILAUTO
Avatar de BILAUTO
Il faudrait que certains nous fassent des retours positifs avec les soft avec lequel cela marche correctement
Je vois que le gars qui parle anglais utiliser le logiciel pour Ford
Vieux 19/08/2018, 10h58   #10
l'intérêt , c'est faire tourner plusieurs soft sur 1 interface et une seule machine
des softs volumineux , des softs qui nécessitent des interfaces
couteuses et spécifiques a chaque marque
concernant ford : forscan , un elm modifié ou obd link sx , fait l'affaire
pour en revenir aux drivers , les packs , je ne vois que ca , en 32/64 bit
https://www.ime-actia.de/index.php/e...thru-xs-api.ht
tout est dans une bonne configuration des le départ
je travail dessus , je ferais des retours !!!!!!!!!!
curtis50 (19/03/2024), fedge (19/08/2018), pouettedu76 (19/08/2018)
Vieux 19/08/2018, 14h19   #11
slt, déjà vida volvo 2014 d fonctionne impec avec Passthru
The Following 4 Users Say Thank You to jeremy72 For This Useful Post:
jah83 (19/08/2018), pouettedu76 (19/08/2018), Y.B tec (05/04/2019), zenata (19/08/2018)
Vieux 19/08/2018, 14h59   #12
jah83
Avatar de jah83
Pouvoir de réputation: 245
Faudrait que je me repenche dessus. Au dernier essai malgré passthruh avdi detecte il voulait pas communiquer
Vieux 10/09/2018, 23h11   #13
Bonsoir
A propos du driver actia passthru 64 bit
j'ai essayé sur windows 10 64 bit , ca ne marche pas
par contre sur windows 7 64 bit et 32 bit , impeccable
donc j'ai monté deux machines virtual box
pour xentry 2018 , une en 64 bit et une en 32 bit , pour comparer
les diags (communication)
merci beaucoup Roturbo , il fallait avoir l'idée , l'astuce !!!!!!!!!
Type de fichier : jpg IMG_0128[1].jpg (89,3 Ko, 85 affichages)
Type de fichier : jpg IMG_0129[1].jpg (90,1 Ko, 69 affichages)
Type de fichier : jpg IMG_0130[1].jpg (90,5 Ko, 65 affichages)
The Following 5 Users Say Thank You to zenata For This Useful Post:
curtis50 (19/03/2024), pouettedu76 (11/09/2018), Roturbo (22/11/2018), SALASH1610 (11/09/2018), vortex (18/03/2019)
Vieux 18/03/2019, 11h31   #14
brejaud
Avatar de brejaud
brejaud is an unknown quantity at this point
Hello
I face problems with Actia XS 1Gen cannot installe driver on x64
Do you have the link and password for the 64 bits drivers ?
Regards
brejaud est déconnecté   Réponse avec citation
Vieux 05/04/2019, 07h03   #15
marikette
Avatar de marikette
marikette has a spectacular aura aboutmarikette has a spectacular aura about
Hello
Please ty
Chercher n'est pas forcément trouver et ce que tu trouves n'est pas toujours ce que tu cherchais.
marikette est déconnecté   Réponse avec citation
ACTIA XS PassThru+ original Shadows93 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 07/05/2018 18h33
Probleme de driver ACTIA 2016 sous win 7 mindouza Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 01/05/2018 05h54
[BDM100] Drivers W7 64bit zouk86 Programmateur de composant (flasher) 0 01/10/2017 10h09
winols en 64bit luce46M57 Logiciel & autres documentations général 3 08/10/2014 13h38
driver actia multidiag 2010 bebert97490 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 7 16/09/2014 14h51
Fuseau horaire GMT +1. Il est actuellement 21h50.
