Vieux 07/01/2018, 15h29   #1
hadil
Avatar de hadil
hadil is a jewel in the roughhadil is a jewel in the roughhadil is a jewel in the rough
Par défaut EGR OFF edc16.34
une personne pourrais svp me metre en egr off
pour une 207 1.6 HDI 2007 ECU EDC16.34
merci a vous
hadil est déconnecté   Réponse avec citation
Vieux 07/01/2018, 16h25   #2
NORDAX
Avatar de NORDAX
NORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond repute
salut a mon avis si tu posterai le dump sa serai plus facile !
NORDAX est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to NORDAX For This Useful Post:
ggvaniou (08/01/2018), zenata (07/01/2018)
Vieux 07/01/2018, 16h48   #3
peug89
Avatar de peug89
peug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to all
EDC16C34
EGR off / ou close :
EGR 1 :
02400 01200 01000 01000 00735 00725 02000 00170 00012 00000 00750 01000 01500 =>
passer à 0 les valeurs dessous :
- OFF 01750 02000 02250 02500 02750 03000 03100 03200 00200 01500 02200 03100
ou close : 00200 01500 02100 02900 03000 03100 03125 03150 03150 03000 02000 01250
EGR 2 :
03100 03100 03125 03150 03150 03000 02000 01250 00012 00000 00750 01000 01250 =>
- OFF : 01500 02000 02250 02500 02750 03000 03100 03200 00100 01000 01600 02000
ou close : 00100 01000 01500 01800 02125 02500 02600 02675 02650 02400 01500 01200
surveillance dft valeur EGR OFF :
- 64036 1500 02700 => 55536 10000 00000 (-10000 / 10000)
- single surveillance egr <rpm (juste après hysté) 00700 => 5000
FAP switch :
8 bits FF hexadécimal
00 7F 00 00 00 00 00 00 00 00 02 01 01 00 0C 3B
OFF : 02 01 => 00 00
chercher 01 00 0C 3B hexadécimal (car pas toujours 00 7F)
peug89 est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to peug89 For This Useful Post:
antoine21703 (21/11/2019), ggvaniou (08/01/2018), guyguy307 (07/01/2018), krimousetif (14/01/2018), nrc04 (21/11/2019), prinzo57 (07/01/2018), redou28 (08/01/2018), rotax (08/01/2018), tony60 (07/01/2018), zenata (07/01/2018)
Vieux 07/01/2018, 16h56   #4
peug89
Avatar de peug89
pour chercher les Hysté EGR faut te mettre en 12 colonnes ;)
Type de fichier : rar DPF EDC16C34 Citroen Peugeot Ford.rar (980,6 Ko, 27 affichages)
antoine21703 (21/11/2019), dingo307 (07/01/2018), floadri (13/01/2018), ggvaniou (08/01/2018), krimousetif (14/01/2018), prinzo57 (07/01/2018), redou28 (08/01/2018), rotax (08/01/2018), soustourou (07/01/2018), zenata (07/01/2018)
Vieux 07/01/2018, 18h43   #5
hadil
Avatar de hadil
Envoyé par hadil Voir le message
merci a vous
mes excuses j avais oublier de metre le dump
Type de fichier : rar ORIGI KADJ.rar (60,8 Ko, 13 affichages)
Vieux 07/01/2018, 19h15   #6
prinzo57
Avatar de prinzo57
Pouvoir de réputation: 43
slt
voici ton egr off
mdp dans ta boite
Type de fichier : rar egr off.rar (60,9 Ko, 7 affichages)
The Following 5 Users Say Thank You to prinzo57 For This Useful Post:
angels59 (08/01/2018), ggvaniou (08/01/2018), hadil (07/01/2018), NORDAX (09/01/2018), peug89 (08/01/2018)
Vieux 07/01/2018, 21h49   #7
hadil
Avatar de hadil
merci je te tien au courant demain
Vieux 08/01/2018, 23h00   #8
hadil
Avatar de hadil
salut prinzo57
merci ca fonctione nickel
The Following 3 Users Say Thank You to hadil For This Useful Post:
NORDAX (09/01/2018), peug89 (08/01/2018), prinzo57 (08/01/2018)
Vieux 21/11/2019, 22h42   #9
nrc04
Avatar de nrc04
nrc04 will become famous soon enoughnrc04 will become famous soon enough
quelqu'un peut confirmer mon egr off svp
edc16c34 c4 picasso 1.6 hdi
avant / apres sur l'image
merci ++
Type de fichier : jpg egr.jpg (97,8 Ko, 20 affichages)
La connaissance s’accroit lorsqu'elle est partagée
nrc04 est déconnecté   Réponse avec citation
Vieux 21/11/2019, 23h12   #10
fenril68
Avatar de fenril68
Pouvoir de réputation: 47
Envoyé par peug89 Voir le message
EDC16C34
EGR 1 :
EGR 2 :
FAP switch :
Bonsoir quelle est la différence entre un egr 1 et un egr 2 ?
Pour moi un egr c’était un EGR
Vieux 22/11/2019, 10h04   #11
Pouvoir de réputation: 175
Pour egr , il faut la laisser branché , si tu débranche tu auras un dtc
Pour egr off , tu peux laisser branché ou débranché pas de dtc qui remonte
Pour egr1 et egr 2 , moi aussi j'ai pas bien saisi, qu'elle différence ?
Vieux 22/11/2019, 10h43   #12
nrc04
Avatar de nrc04
ce ne sont pas des maps egr mais egr fonction air temperature elle sont juste apres la map egr je crois
The Following User Says Thank You to nrc04 For This Useful Post:
fenril68 (22/11/2019)
Edc16 vag formator2 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 2 19/01/2020 14h12
Need EGR OFF EDC16 BAZBOZ Chiptuning 5 05/04/2017 15h31
EDC16 C4 HDI 110 fap mckeller Réparation & Programmation 41 13/08/2014 18h36
Egr off edc16 c 34 jphp Chiptuning 7 06/01/2014 21h54
Mpc EDC16 sampro Programmateur de composant (flasher) 0 31/03/2011 21h07
Fuseau horaire GMT +1. Il est actuellement 20h15.
