Vieux 20/07/2017, 14h00   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut DiagBox Firmware: Appli 8.3.5 + BT 1.2.4
The software provided is intended for personal, educational and experimental use; to help with DiagBox installations and XS Evolution VCI communication. I hold no responsibility for any illegal or improper usage or any damage to your system. Carry out upgrade at your own risk.
For those interested in experimenting with the different DiagBox firmware versions, I have attached the latest (to-date) Application (Appli.com 4.3.5, DiagBox v8.45) and Blue Tooth (1.2.4, DiagBox v8.43) Firmware.
I have also included the older BT firmware (1.2.3, DiagBox v8.30) as it includes the HEX file, in case someone needs it.
Simple..
Type de fichier : zip App+BT_Firmware.zip (380,6 Ko, 217 affichages)
Simple est déconnecté   Réponse avec citation
The Following 35 Users Say Thank You to Simple For This Useful Post:
2009mohrice (20/07/2017), abdel93 (25/12/2017), adiago (20/07/2017), alsacien (28/08/2017), autodiagauto (28/09/2017), bebert1234 (22/10/2017), bej 974 (21/07/2017), Bllinda (18/06/2024), DIAGAUTO33 (20/07/2017), didi_du_93000 (27/04/2018), djslowrnb (26/09/2017), ecutech (20/07/2017), elie (12/11/2017), foulques (20/07/2017), guyguy307 (20/07/2017), hichamdz128 (27/01/2018), Ian995 (14/11/2018), jerome110383 (28/09/2017), natouss225 (26/02/2026), Nextrick (02/10/2017), nounour10 (10/01/2020), octave (04/08/2017), Redha-TE (29/01/2019), REDZONE31 (20/07/2017), Roturbo (29/08/2017), samii1955 (21/07/2017), sivestiano (24/09/2019), tatel (02/02/2018), taxi5114 (30/09/2017), tony60 (20/07/2017), youcef_trik (02/10/2017), yoyomartin2003 (22/07/2017), yvespapou (20/07/2017), zagor (09/02/2018), zenata (27/09/2017)
Vieux 24/07/2017, 16h45   #2
Simple
Avatar de Simple
The are 2 ways of up****** XS Evolution VCI Firmware,
1- Automatic up******, Follow instructions in this link:
http://www.tlemcen-electronic.com/fo...560#post540560
2- Manual up******, download and install "PSA Interface Checker Install.exe",
a- Ensure XS Evolution VCI is connected and recognised
b- Click on Activate, greyed buttons will become active
c- Click Version to check current version
d- Click Select file to choose the Firmware file desired for upgrade
e- Click Downloading to start the flashing process.
Please wait 5 seconds after the flashing process finished and before disconnecting or starting other application, to ensure no flashing corruption.
The Following 5 Users Say Thank You to Simple For This Useful Post:
autodiagauto (28/09/2017), daimler (18/12/2018), djslowrnb (26/09/2017), octave (04/08/2017), zenata (27/09/2017)
Vieux 26/09/2017, 13h06   #3
djslowrnb
Avatar de djslowrnb
djslowrnb is on a distinguished road
Thanks simple i use version 7.83 how to know the good firmware fot this version depend car to dagnostic?
thanks!!!
djslowrnb est déconnecté   Réponse avec citation
Vieux 26/09/2017, 22h53   #4
Simple
Avatar de Simple
DiagBox from version 7.66/8.02 to 8.44 has 4.3.4, but users have used other versions successfully.
Vieux 26/09/2017, 23h17   #5
djslowrnb
Avatar de djslowrnb
Envoyé par Simple Voir le message
Thanks Simple, you Maitresox et Scary we are the best !!!!
Vieux 27/09/2017, 22h15   #6
djslowrnb
Avatar de djslowrnb
Thanks you is the best!!!
Vieux 01/10/2017, 21h20   #7
djslowrnb
Avatar de djslowrnb
Hello simple
I have problem to dialog with my car 308 year 2008
VCI sporadig not read VIN and not read units
I test with many version firmware and result is the same my vci is not good?
But with old 6.16 i not have this problem...
Nlc have flash my unit in 2014
Vieux 01/10/2017, 21h28   #8
Simple
Avatar de Simple
Was the VCI working with the same 308? Try using your VCI with another Peugeot or Citroen car and see if it detects it. Is the Windows Driver installing and working OK?
Some VCI's have a problem with C5 and 207/208. More experienced forum members may be able to help!!
Vieux 02/10/2017, 01h07   #9
djslowrnb
Avatar de djslowrnb
thanks for response Simple!!
I have problem when i read vin, the read fonction at random the diagnostic is not good....
i see the message connect vci....
I try to update other firmware and one time i see peripheric is not reconize but now its ok i daed my VCI?probably?
regards !!
The Following User Says Thank You to djslowrnb For This Useful Post:
mike3021 (10/11/2023)
OPCOM Firmware 1.70 djrusskof Opcom, Tech2 21 19/02/2019 17h36
appli smarthphone pour decoder poste renault diagologie Autoradio et Navigateur GPS 4 04/09/2016 16h30
recherche firmware aPPLI 4.3.3 et 4.3.4 jasmin LEXIA, PP2000, DiagBox 15 07/05/2015 10h25
Update diagbox 7.40 et firmware 4.3.2 CED300482 LEXIA, PP2000, DiagBox 8 23/04/2014 22h57
demande d'appli antvan Probleme des membres 1 13/01/2014 11h02
Fuseau horaire GMT +1. Il est actuellement 00h02.
