Vieux 23/02/2017, 15h51   #1
RALPH
Avatar de RALPH
Par défaut Diagbox
salut a tous, je recherche une mise a jour en francais de diagbox; j ai la version 7.66. j ai une version 7.77 mais elle passe en anglais.
Vieux 23/02/2017, 16h13   #2
Ian995
Avatar de Ian995
Ian995 is an unknown quantity at this point
For change Language :
For DiagBox:
Open the File Explorer and navigate to "C:\AWRoot\dtrd\trans\"language.ini"
Open the file Language.ini and under [LANGUAGE], change "Current=en_GB" to "Current="select country on the screen" and save.
For Lexia:
GO to "C:\APP\LEXIA\EXE\" find the file "Dico.txt" Change Dico=THELEXFR.DBZ to GB for English
For PP2000:
Go to "C:\APP\OUTILREP\EXE\" find the file "Dico.txt" Change Dico=THESAUFR.DBZ to GB for English
Ian995 est déconnecté   Réponse avec citation
Vieux 23/02/2017, 16h18   #3
RALPH
Avatar de RALPH
effectivement, ce n est que sur lexia et pp2000 merci je vais essayer. et après la 7.77?
Vieux 23/02/2017, 16h22   #4
Ian995
Avatar de Ian995
Cela fonctionnera très bien sur v7.77 et au-dessus
Merci Ian
Vieux 24/02/2017, 09h03   #5
RALPH
Avatar de RALPH
j ai mis a jour la 7.76 quelqu'un aurais une mis a jour plus récent version 7.
Vieux 24/02/2017, 09h34   #6
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
For DiagBox updates, try this:
http://www.tlemcen-electronic.com/fo...ad.php?t=64153
DiagBox language can be changed through the menu for releases up to 7.72 /8.08. Installing updates should not affect the set language (usually).
However, for releases higher than 7.72/8.08, you need to perform manual changes to some configuration files as mentioned previously, as well as in "C:\APP\LEXIA\EXE\langue.ini"
[DicoMap]
CITACT=..\Dico\CITACT%LG%.dbz,APV
CITTT=..\Dico\CITTT%LG%.dbz,APV
CITTV=..\Dico\CITTV%LG%.dbz,APV
THESAU=..\Dico\THESAU%LG%.dbz,APV
Change %LG% in the 4 statements to the language of your choice, FR, GB, etc.. Example:
THESAU=..\Dico\THESAU%LG%.dbz,APV --> THESAU=..\Dico\THESAUFR.dbz,APV
Simple est déconnecté   Réponse avec citation
Vieux 10/03/2017, 11h11   #7
RALPH
Avatar de RALPH
salut a tous, je recherche mise a jour 7.76 vers 7.??? si quelqu un aquelque chose merci.
Vieux 11/03/2017, 12h27   #8
binhex
Avatar de binhex
binhex is just really nicebinhex is just really nicebinhex is just really nicebinhex is just really nice
Envoyé par RALPH Voir le message
regarde un peux le forum....tout y est , ça entre autres !..
http://www.tlemcen-electronic.com/fo...ad.php?t=48970
diagbox 7.76 aimanj750 PSA Group Peugeot, Citroën 2 04/07/2016 15h37
Lexia, diagbox... Vin Lu par diagbox mais pas de communication avec les calculateurs julien34560 LEXIA, PP2000, DiagBox 24 13/12/2015 10h42
Diagbox Montpel34 Automobile en général 9 15/07/2015 07h13
diagbox v6 allthe77man LEXIA, PP2000, DiagBox 1 07/03/2012 23h54
Fuseau horaire GMT +1. Il est actuellement 11h59.
