Vieux 07/02/2017, 23h04   #1
salemsim
Avatar de salemsim
salemsim will become famous soon enough
Par défaut Xprog 5.55 ?
quel est la différence entre un xprog 5.55 avec dongle et xprog 5.55 sans dongle ?
a quoi sert dongle ?
Envoyé de mon SM-G531F en utilisant Tapatalk
salemsim est déconnecté   Réponse avec citation
Vieux 08/02/2017, 23h31   #2
Criptic
Avatar de Criptic
Criptic has a spectacular aura aboutCriptic has a spectacular aura aboutCriptic has a spectacular aura about
No difference.
Why do you need a USB dongle?
Better without dongle
Type de fichier : jpg usb-dongle-connected-to-laptop-259360.jpg (83,0 Ko, 43 affichages)
If I not help you, or you do not like my posts anyway click thanks
Criptic est déconnecté   Réponse avec citation
Vieux 08/02/2017, 23h47   #3
salemsim
Avatar de salemsim
I haven't xprog and I want buy one, because that I'm asking.
Thanks my friend
Vieux 08/02/2017, 23h57   #4
Criptic
Avatar de Criptic
Buy 5.0 after reflash to version 555
So it will be cheaper
For all firmware can be found on the forum
Vieux 09/02/2017, 00h02   #5
salemsim
Avatar de salemsim
What you think about 5.6 or 5,7 ?
Is there deference between them and version 5.55?
Thanks
Vieux 09/02/2017, 00h07   #6
Criptic
Avatar de Criptic
XProg 5.55
https://mega.nz/#!PRBHlARI!YdeaHrZuA...rPBdpupIDU3LOo
The Following 5 Users Say Thank You to Criptic For This Useful Post:
autodiagauto (07/02/2024), jardini (01/12/2020), psychoneos (11/04/2020), salemsim (09/02/2017), speedy_bou (01/11/2017)
Vieux 09/02/2017, 00h08   #7
Criptic
Avatar de Criptic
Envoyé par salemsim Voir le message
Thanks
I can not answer you. I use the 555 version
Vieux 09/02/2017, 01h19   #8
salemsim
Avatar de salemsim
Thanks for your advice, I hope one tell us the deference
Vieux 21/04/2017, 02h49   #9
Jumpman
Avatar de Jumpman
Jumpman is an unknown quantity at this point
Salut moi je viens d'installer la version 5.55 et si je ne mets pas le d'ongles impossible de le lancer
Jumpman est déconnecté   Réponse avec citation
Vieux 04/02/2024, 18h35   #10
nrd0991
Avatar de nrd0991
nrd0991 is on a distinguished road
je déterre ce post, je compte acheter un xprog 5.55, que pensez vous de celui la
https://www.aliexpress.com/item/1005...Cquery_from%3A
sans dongle. faut il le mettre à jour pour une version plus stable ou plus récente ?
nrd0991 est déconnecté   Réponse avec citation
Vieux 04/02/2024, 19h48   #11
Pelican
Avatar de Pelican
Compatible XP 32bit.
Ou Windows 7 64bit.
Windows 10 ne passe pas dessus !
Et fonctionne hors ligne seulement attention !
nrd0991 (05/02/2024)
Vieux 05/02/2024, 19h03   #12
nrd0991
Avatar de nrd0991
merci pour la réponse Prlican,
est ce que je peux installer le soft v5.55 du vendeur ou il existe une version plus sûr à chercher sur internet peut-être sur T-E.
une autre question même si ça m’étonne que la réponse est oui : peut on l'upgrader à la dernière version v5? la v5.84 il me semble, comme ça se fait pour les versions plus anciennes que la 5.55 (5.0 5.51 ...)vers la 5.55.
Vieux 07/02/2024, 09h11   #13
Pelican
Avatar de Pelican
je l'ai installé avec le logiciel du vendeur !
En respectant les consignes.
Ça va très bien comme ça!
nrd0991 (07/02/2024)
Vieux 07/02/2024, 17h36   #14
nrd0991
Avatar de nrd0991
ok. merci pour l'info Pelican
The Following User Says Thank You to nrd0991 For This Useful Post:
Pelican (07/02/2024)
Différence entre xprog et xprog-m figeac Programmateur de composant (flasher) 1 13/09/2024 14h45
Xprog 5.60 chaoui05 Programmateur de composant (flasher) 3 07/09/2016 14h38
xprog 5.55 allpatchi Programmateur de composant (flasher) 2 06/09/2016 22h41
xprog-m v5.0 angelman Programmateur de composant (flasher) 2 03/10/2013 17h08
Fuseau horaire GMT +1. Il est actuellement 15h20.
