Vieux 15/12/2008, 20h07   #1
didi_du_93000
Avatar de didi_du_93000
Par défaut I change the dash on Audi A3 TDI 2001 and the car didn't turn on
Hello,:):)
I change the dashboard on my audi A3, and now the car didn't tur on because the Immo is active.
I would like to remove the immo.
Please help me. :confused::confused:
Thanks
Didi
Vieux 15/12/2008, 20h39   #2
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1335
when you complete your profile we will help u ;)
Regards
🚀 MOD-FILES.COM
Amine-TE est connecté maintenant   Réponse avec citation
Vieux 15/12/2008, 22h00   #3
didi_du_93000
I don't understand My profile is complete.
What is the problem?
Vieux 15/12/2008, 22h55   #4
jayontime
Avatar de jayontime
jayontime is on a distinguished road
Question profile
you need to put where in paris i think like country then place
hope this helps
Remapping file service please join good priced files
https://premier-remapping.com
jayontime est déconnecté   Réponse avec citation
Vieux 15/12/2008, 22h57   #5
jayontime
Avatar de jayontime
Par défaut oh oh
oh oh and read rules?
thats what i was told
same gose for every one els i think read rules more than once and
update profile with correct country and town
Vieux 16/12/2008, 14h41   #6
didi_du_93000
And now it's ok???
Vieux 16/12/2008, 14h51   #7
Amine-TE
Fondateur
Avatar de Amine-TE
You can remove the old eprom from the old dash then solder it in the new one and the car will start ;)
🚀 MOD-FILES.COM
Vieux 16/12/2008, 14h57   #8
didi_du_93000
Envoyé par Tlemcen-Electronic Voir le message
If i turn off the immo on the ecu. the car turn on with the new dashboard?
On this dashborad the km is on the 68HC912. But the pin i don't know if it's on the same processour or no.
You know where is the pin and if is it possible for change this pin?
Vieux 16/12/2008, 15h36   #9
Amine-TE
Fondateur
Avatar de Amine-TE
I dont know the adress for pin code, but try to see VagTacho if can do this job :)
🚀 MOD-FILES.COM
Vieux 16/12/2008, 16h01   #10
jayontime
Avatar de jayontime
Par défaut pin
pos:Dt file and i will look at it for you
Vieux 16/12/2008, 16h21   #11
didi_du_93000
i open the ECU. i found the eeprom 24c04. I would like to remove th immo.
But on Immokiller v1.10 he say it's a 24c02.
the ecu is a Bosch (0 281 010 308)
i joint the pictures.
What my soltion? :confused::confused:
thanks
Dernière modification par didi_du_93000 ; 21/11/2011 à 23h52.
Vieux 16/12/2008, 21h59   #12
Amine-TE
Fondateur
Avatar de Amine-TE
Yes, use immokiller then check your PM
🚀 MOD-FILES.COM
Vieux 18/12/2008, 21h50   #13
didi_du_93000
Hello, A friend remove the immo on my Audi A3. he use edc soft.
You know this soft?
I think it's not possible with IMMOKILLER because my ECU is a bosch edc15p+
thanks.
Vieux 19/12/2008, 11h52   #14
didi_du_93000
Envoyé par 7Hex4 Voir le message
If you have hc912dg128 in dash the pin code is in address $84 and &85,
convert from hex to decimal
Br
Ho!!!!
Thanks for this infomation...
Very good information for the futur. ;)
Fuseau horaire GMT +1. Il est actuellement 20h29.
