Vieux 20/10/2010, 08h54   #1
franckr
Avatar de franckr
franckr is on a distinguished road
Arrow => HDI Siemens SID 803
Tout savoir sur le système HDI Siemens SID 803 monté sur C4 et C5
Document Pdf Citroën de 129 pages
GLOSSAIRE
CARACTERISTIQUES PARTICULIERES
PRESENTATION
I - PRESENTATION
CONNECTIQUE
I - BROCHAGE CALCULATEUR
II - ENTREES / SORTIES CALCULATEUR
PRINCIPE DE FONCTIONNEMENT
I - CALCUL DE LA QUANTITE DE CARBURANT A INJECTER
II - CORRECTION EN PHASE DEMARRAGE
III - FONCTIONNEMENT DANS LES REGIMES TRANSITOIRES
IV - GESTION DES DEFAUTS
V - STRATEGIES DE SECOURS
DETECTION DES DEFAUTS
. LES CAPTEURS DE TEMPERATURE
VI - TEMPERATURE D'AIR ADMISSION (DEBIMETRE)
VII - TEMPERATURE D'AIR ADMISSION (REPARTITEUR AIR ADMISSION)
VIII - TEMPERATURE D’EAU MOTEUR
IX - TEMPERATURE GAZOLE
X - TEMPERATURE AVAL CATALYSEUR
. LES ALIMENTATIONS ET RELAIS
XI - TENSION BATTERIE
XII - COMMANDE RELAIS D’ALIMENTATION
XIII - COMMANDE RELAIS DE PUISSANCE
XIV - CIRCUIT RELAIS PRE-POST CHAUFFAGE
XV - ALIMENTATION 5V N°1
XVI - ALIMENTATION 5V N°2
. LA BOUCLE D’AIR
XVII - SIGNAL PRESSION ATMOSPHERIQUE
XVIII - SIGNAL DEBITMETRE
. LA GESTION DES GAZ D’ECHAPPEMENT
XIX - SIGNAL PRESSION DIFFERENTIELLE ECHAPPEMENT
XX - FILTRE A PARTICULES
XXI - SYSTEME ADDITIVATION
. LA SURALIMENTATION
XXII - SIGNAL PRESSION DE TURBO
XXIII - COMMANDE ELECTROVANNE PRESSION TURBO
XXIV - SIGNAL DE RECOPIE POSITION VANNE TURBO
. LA FONCTION EGR
XXV - RECYCLAGE DES GAZ D’ECHAPPEMENT (EGR)
XXVI - SIGNAL DE RECOPIE POSITION ELECTROVANNE EGR
XXVII - COMMANDE ELECTROVANNE EGR
. LES PAPILLONS
XXVIII - BOITIER PAPILLON EGR
XXIX - BOITIER PAPILLON RECHAUFFAGE AIR ADMISSION
. LA POMPE HP
XXX - SIGNAL PRESSION CARBURANT
XXXI - ELECTROVANNE DE REGULATION DE PRESSION CARBURANT
XXXII - ELECTROVANNE DE REGULATION DE DEBIT CARBURANT
XXXIII - REGULATION DE PRESSION CARBURANT
. LES INJECTEURS
XXXIV - CONVERTISSEUR DE TENSION DES INJECTEURS
XXXV - COMMANDE INJECTEURS
XXXVI - COMMANDE INJECTEUR CYLINDRE 1
XXXVII - COMMANDE INJECTEUR CYLINDRE 2
XXXVIII - COMMANDE INJECTEUR CYLINDRE 3
XXXIX - COMMANDE INJECTEUR CYLINDRE 4
XL - CORRECTION DE DEBIT INJECTEUR
. LES CAPTEURS
XLI - SIGNAL REGIME MOTEUR
XLII - SIGNAL REFERENCE CYLINDRE
XLIII - SIGNAL PEDALE ACCELERATEUR PISTE1
XLIV - SIGNAL PEDALE ACCELERATEUR PISTE2
XLV - SIGNAL PEDALE D’ACCELERATEUR
XLVI - SIGNAL VITESSE VEHICULE
XLVII - SIGNAL CONTACTEUR D’EMBRAYAGE
XLVIII - SIGNAL CONTACTEUR DE FREIN
. LES ACCESSOIRES
XLIX - CIRCUIT CHAUFFAGE ADDITIONNEL
L - FONCTION REFROIDISSEMENT INTEGREE AU CALCULATEUR
LI - COMMANDE VENTILATEUR GRANDE VITESSE/ VITESSE VARIABLE
LII - COMMANDE VENTILATEUR PETITE VITESSE
LIII - SIGNAL PRESSION REFRIGERATION
LIV - ELECTROVANNE DE DEGAZAGE CIRCUIT DE REFROIDISSEMENT
LV - ELECTROVANNE BY-PASS CIRCUIT DE REFROIDISSEMENT
. LES "SAFETY"
LVI - CALCULATEUR INJECTION
. CAN / DIVERS
LVII - PAS DE COMMUNICATION SUR LE RESEAU (CAN)
LVIII - RECEPTION CALCULATEUR DU RESEAU CAN CONFORT
LIX - RECEPTION CALCULATEUR ESP
LX - RECEPTION CALCULATEUR ABS
LXI - REVEIL CALCULATEUR COMMANDE A DISTANCE
LXII - DEMARRAGE ET ARRET MOTEUR PILOTES
LXIII - COMMUNICATION SUR LE CAN CONFORT
LXIV - COMMUNICATION SUR LE CAN CARROSSERIE
LXV - SYSTEME D’ADDITIVATION
LXVI - NIVEAU DE CARBURANT
LXVII - TEST COUPURE ALIMENTATION INJECTION A L’ARRET MOTEUR
OPERATIONS APRES VENTE
I - FAISCEAU DERIVATEUR
II - TELECODAGE
III - APPRENTISSAGE
IV - RAPPEL
ANNEXES
Dernière modification par franckr ; 17/11/2010 à 08h07.
franckr est déconnecté   Réponse avec citation
The Following 18 Users Say Thank You to franckr For This Useful Post:
Baldman (25/03/2015), beloukio (24/06/2020), Dali01 (13/11/2010), eobd-scan92 (23/10/2010), fedge (13/11/2010), hioub (21/02/2020), jpay2 (25/03/2014), jroz (07/02/2021), laguna3 (12/11/2010), Mitch82 (20/10/2010), mo59760 (31/05/2020), mounelou (30/05/2026), nadjibdiag43 (04/05/2020), neiji (20/10/2010), passemoi (20/10/2010), ptitom33 (20/10/2010), RANA (08/11/2010), walbou (08/11/2010)
Vieux 24/01/2017, 11h25   #2
DDJAM
Avatar de DDJAM
DDJAM is on a distinguished road
Par défaut svp reupload !!
salut ,svp qui peut reuploder ce fichier j'en ai vraiment besoin, merci
DDJAM est déconnecté   Réponse avec citation
Vieux 24/01/2017, 11h28   #3
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Pouvoir de réputation: 44
Sa serai vraiment utile pour tout le monde
Vieux 24/01/2017, 11h30   #4
DIAGSYSTEM25
Sa serai un lien utile pour tout le monde
Vieux 24/01/2017, 11h48   #5
peug89
Avatar de peug89
peug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to all
J'ai trouvé une doc de 132pages SID803 lien ici :
https://www.slideserve.fr/download/d...iemens-sid-803
Cdt
peug89 est déconnecté   Réponse avec citation
The Following User Says Thank You to peug89 For This Useful Post:
AHMED@UTO (04/04/2022)
Vieux 05/02/2017, 03h33   #6
djimer
Avatar de djimer
djimer is an unknown quantity at this point
Wink
Envoyé par peug89 Voir le message
Cdt
un grand merci a toi pour ton partage ,tres intéressant
djimer est déconnecté   Réponse avec citation
The Following User Says Thank You to djimer For This Useful Post:
rapou30 (06/03/2020)
Vieux 05/02/2017, 12h46   #7
peug89
Avatar de peug89
mais de rien ;) j'ai googlé juste avec des "+" entre chaque mots au lieu des espaces = résultats plus précis pour le moteur de recherche "+" = et / "espace" = ou
voila voila (merci surtout à celui qui l'a mise en ligne )
Vieux 21/02/2020, 22h17   #8
hioub
Avatar de hioub
Pouvoir de réputation: 8
hioub is on a distinguished road
Hello!
merci pour l'existence de ce doc. Quelqu'un connait bien ce siemens?
hioub est déconnecté   Réponse avec citation
Vieux 05/03/2020, 23h41   #9
hioub
Avatar de hioub
voici un excellent lien!
https://mega.nz/#F!ULQwjKCI!70F98el3L_cYYUqXWYQbqg
The Following 2 Users Say Thank You to hioub For This Useful Post:
AHMED@UTO (04/04/2022), rapou30 (06/03/2020)
Vieux 08/03/2020, 14h28   #10
karera 1
Avatar de karera 1
lien n'est plus valide
Vieux 08/03/2020, 14h36   #11
hioub
Avatar de hioub
je suis désolé.
Vieux 09/03/2020, 16h37   #12
nicoc5
Avatar de nicoc5
nicoc5 is on a distinguished road
bonjour,
karea 1 si tu désire toujours le lien
https://mega.nz/#F!xLQH2KAY!
précision celà concerne la remise en état de certaines des pompes du groupe Continental/Siemens
clé en MP
a+
nicoc5 est déconnecté   Réponse avec citation
The Following User Says Thank You to nicoc5 For This Useful Post:
Vieux 01/11/2021, 21h11   #13
NightEye
Avatar de NightEye
NightEye is on a distinguished road
Juste en passant, ayant eu à chercher cette doc, je l'ai trouvée ici (tant que le lien fonctionne) :
https://pdfcookie.com/download/injec...3-9025zq8m0421
NightEye est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to NightEye For This Useful Post:
mounelou (23/09/2025), pp08 (01/11/2021)
Immo off siemens sid 803 lari95400 Immobilizer dumps/solutions 6 21/06/2010 09h55
airbag 307 siemens hakimalarme Airbag 1 30/03/2010 19h07
siemens SID DIAGMOH Vente, Achat, Echange 0 29/12/2009 20h38
307 HDI 90 Siemens slv Immobilizer dumps/solutions 10 19/10/2009 23h14
Fuseau horaire GMT +1. Il est actuellement 05h27.
