Hi.
Does it work? This is my mix of version 5.55 and 5.70. I do not have such devices to check. XProg is trying to work with devices. Added new: MCU/MPU Freescale 9S12XF MC9S12XF128_EEE MC9S12XF128_D-FLASH MC9S12XF128_P-FLASH MC9S12XF256_EEE MC9S12XF256_D-FLASH MC9S12XF256_P-FLASH MC9S12XF384_EEE MC9S12XF384_D-FLASH MC9S12XF384_P-FLASH MC9S12XF512_EEE MC9S12XF512_D-FLASH MC9S12XF512_P-FLASH Freescale (MPC560x) MPC5604P_Code_Flash MPC560xB/C/P_Data_Flash MPC560xB/C/P_Code_Flash_Test MPC560xB/C/P_Code_Flash_Shadow MPC560xB/C/P_Test_Flash_Block Freescale (MPC55xx) MPC5515_Code_Flash MPC5516_Code_Flash MPC5517_Code_Flash MPC551x_Shadow SPC560 SPC560B40Lx_CODE_FLASH SPC560B40Lx_DATA_FLASH SPC560Bxx_code_flash_test SPC560Bxx_code_flash_shadow SPC560Bxx_test_flash_block SPC560C40Lx_CODE_FLASH SPC560C40Lx_DATA_FLASH SPC560C50Lx_CODE_FLASH SPC560C50Lx_DATA_FLASH SPC560Cxx_code_flash_test SPC560Cxx_code_flash_shadow SPC560Cxx_test_flash_block Immobilizers Yamaxa T-MAX_Type_I_9S12T64 T-MAX_Type_II_9S12T64 Other ECU Chrysler-Dodge-Jeep (MPC5515) BCM-GRAND_CHEROKEE_WK_2014_Flash BCM-GRAND_CHEROKEE_WK_2014_Shadow Renault Clio III EPS_ST10F269 EPS_ST10F269->24C16 VOLVO (MPC5516) VOLVO_CCM_Flash Airbag (XC2xxx) FR3T-14B321-AF(XC2336A-72) FR3T-14B321-AF flash0 FR3T-14B321-AF flash1 FR3T-14B321-AF flash3 Airbag (SPC560xx/MPC560x) SPC560P50L3_Honda_CR-V Code_Flash Data_Flash Honda_Jazz (SC667051/MPC5604P 0M26V) Code_Flash Data_Flash Renault (SPC560P50L3) Code_Flash Data_Flash VW_Golf7 (SPC560P50L3) Code_Flash Data_Flash
>> As I helped you please press THANKS, REP. << |
version 5.5.5 or 5.7.0 ?????
Banned
working with clones ?
Hi.
This is mix... more than 5.55 less than 5.70 yes... (the second link)
File has been removed due to inactivity
pouvez vous le recharger une autre fois sur mega svp merci |
Hi.
New link...
slt!
Virus sur l'exe... et c'est pas juste un exe modifié, un virus y est attaché (on peut le virer en le nettoyant). Bref j'ai pas pu tester ms je vois effectivement qu'il y a de nouvelles activations. ++ |
| Outils de la discussion | |
| Différence entre xprog et xprog-m | figeac | Programmateur de composant (flasher) | 1 | 13/09/2024 14h45 |
| Quelle version de xprog | Maza | Programmateur de composant (flasher) | 1 | 05/06/2021 02h11 |
| Installation AK500 Version 1.92 et AK500 PRO version 2.002 + SKC + Base de données | BILAUTO | Mercedes Benz | 16 | 20/11/2017 21h53 |
| Procédure pour installer DiagBox de la version 7.01 à la version 7.850 | zenata | LEXIA, PP2000, DiagBox | 0 | 16/11/2017 16h24 |
| mise a jour can clip Version 124 vers Version 125 | deedee | Renault clip, DDT2000, Nissan consult | 3 | 27/03/2013 20h12 |
