Vieux 29/06/2016, 21h58   #1
Criptic
Avatar de Criptic
Criptic has a spectacular aura aboutCriptic has a spectacular aura aboutCriptic has a spectacular aura about
Par défaut Pin code NISSAN Almera
Hello. Help please calculate the pin on the dump. Nissan Almera 1.8L 2003 NATS 6. No sticker on the BCM
Type de fichier : bin Almera 93c66 BCM Nats 6.bin (512 octets, 14 affichages)
If I not help you, or you do not like my posts anyway click thanks
Criptic est déconnecté   Réponse avec citation
Vieux 29/06/2016, 22h51   #2
aza
Avatar de aza
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
HI Criptic
in NISSAN NATS 6 :
device is a 93c66 :
pin is located at the following address :_ (A9_____AA)
(A9_____AA) = 0201
salutations
aza est déconnecté   Réponse avec citation
The Following User Says Thank You to aza For This Useful Post:
diagnosis29 (30/06/2016)
Vieux 29/06/2016, 23h00   #3
Criptic
Avatar de Criptic
Thank you so much. Tomorrow I will try.
Vieux 29/06/2016, 23h11   #4
Criptic
Avatar de Criptic
Tango gives pin 0000. The Advanced Code Evo says that the dump invalid.
Vieux 30/06/2016, 07h13   #5
Criptic
Avatar de Criptic
Envoyé par aza Voir le message
HI Criptic
in NISSAN NATS 6 :
device is a 93c66 :
(A9_____AA) = 0201
salutations
FVDI says PIN code is incorrect. Maybe my dump broken. Do you have a working dump BCM end ECM?
Vieux 07/07/2016, 19h51   #6
Criptic
Avatar de Criptic
BCM unit has been damaged. I replaced the defective block.After I wrote a working dump pin was known to me. Put the keys and the car came to life.
I did not understand where is the pin in the dump
Type de fichier : bin Nissan Almera 2003 MT BCM NATS 6 (93C66) pin 0881.bin (512 octets, 14 affichages)
Programmation cle nissan almera? walteck programmation & synchronisation de clé 0 01/12/2015 12h21
Code autoradio Nissan Almera Clarion tn2316m mourad44 Autoradio et Navigateur GPS 2 30/10/2014 23h15
immo off nissan almera ryosaeba Immobilizer dumps/solutions 0 15/09/2014 10h03
Nissan almera sdesign Immobilizer dumps/solutions 16 22/08/2013 17h47
Fuseau horaire GMT +1. Il est actuellement 20h12.
