Vieux 17/04/2016, 15h35   #1
minimex
Avatar de minimex
minimex will become famous soon enough
Par défaut Xprog - mix of version 5.55 and 5.70
Hi.
Does it work?
This is my mix of version 5.55 and 5.70.
I do not have such devices to check.
XProg is trying to work with devices.
Added new:
MCU/MPU
Freescale 9S12XF
MC9S12XF128_EEE
MC9S12XF128_D-FLASH
MC9S12XF128_P-FLASH
MC9S12XF256_EEE
MC9S12XF256_D-FLASH
MC9S12XF256_P-FLASH
MC9S12XF384_EEE
MC9S12XF384_D-FLASH
MC9S12XF384_P-FLASH
MC9S12XF512_EEE
MC9S12XF512_D-FLASH
MC9S12XF512_P-FLASH
Freescale (MPC560x)
MPC5604P_Code_Flash
MPC560xB/C/P_Data_Flash
MPC560xB/C/P_Code_Flash_Test
MPC560xB/C/P_Code_Flash_Shadow
MPC560xB/C/P_Test_Flash_Block
Freescale (MPC55xx)
MPC5515_Code_Flash
MPC5516_Code_Flash
MPC5517_Code_Flash
MPC551x_Shadow
SPC560
SPC560B40Lx_CODE_FLASH
SPC560B40Lx_DATA_FLASH
SPC560Bxx_code_flash_test
SPC560Bxx_code_flash_shadow
SPC560Bxx_test_flash_block
SPC560C40Lx_CODE_FLASH
SPC560C40Lx_DATA_FLASH
SPC560C50Lx_CODE_FLASH
SPC560C50Lx_DATA_FLASH
SPC560Cxx_code_flash_test
SPC560Cxx_code_flash_shadow
SPC560Cxx_test_flash_block
Immobilizers
Yamaxa
T-MAX_Type_I_9S12T64
T-MAX_Type_II_9S12T64
Other ECU
Chrysler-Dodge-Jeep (MPC5515)
BCM-GRAND_CHEROKEE_WK_2014_Flash
BCM-GRAND_CHEROKEE_WK_2014_Shadow
Renault Clio III
EPS_ST10F269
EPS_ST10F269->24C16
VOLVO (MPC5516)
VOLVO_CCM_Flash
Airbag (XC2xxx)
FR3T-14B321-AF(XC2336A-72)
FR3T-14B321-AF flash0
FR3T-14B321-AF flash1
FR3T-14B321-AF flash3
Airbag (SPC560xx/MPC560x)
SPC560P50L3_Honda_CR-V
Code_Flash
Data_Flash
Honda_Jazz (SC667051/MPC5604P 0M26V)
Code_Flash
Data_Flash
Renault (SPC560P50L3)
Code_Flash
Data_Flash
VW_Golf7 (SPC560P50L3)
Code_Flash
Data_Flash
Type de fichier : jpg x1.jpg (19,6 Ko, 53 affichages)
Type de fichier : jpg x2.jpg (19,1 Ko, 26 affichages)
Type de fichier : jpg x3.jpg (19,8 Ko, 9 affichages)
Type de fichier : jpg x4.jpg (20,2 Ko, 28 affichages)
Type de fichier : txt link.txt (52 octets, 37 affichages)
>> As I helped you please press THANKS, REP. <<
minimex est déconnecté   Réponse avec citation
Vieux 19/04/2016, 21h04   #2
minimex
Avatar de minimex
Hi.
Improved software, apparently now it's ok
www.megafileupload.com/nkeL/XProg5.55_mix.zip
Vieux 19/04/2016, 21h19   #3
BILAUTO
Avatar de BILAUTO
Pouvoir de réputation: 59
version 5.5.5 or 5.7.0 ?????
Vieux 20/04/2016, 21h27   #4
escargot08
Banned
Avatar de escargot08
escargot08 will become famous soon enough
working with clones ?
escargot08 est déconnecté   Réponse avec citation
Vieux 20/04/2016, 22h57   #5
minimex
Avatar de minimex
Hi.
Envoyé par BILAUTO Voir le message
This is mix...
more than 5.55
less than 5.70
Envoyé par escargot08 Voir le message
yes... (the second link)
Vieux 28/06/2016, 21h38   #6
mohcin2
Avatar de mohcin2
mohcin2 will become famous soon enough
File has been removed due to inactivity
pouvez vous le recharger une autre fois sur mega svp merci
mohcin2 est déconnecté   Réponse avec citation
Vieux 05/10/2016, 02h05   #7
minimex
Avatar de minimex
Hi.
New link...
Type de fichier : txt link.txt (83 octets, 3 affichages)
Vieux 05/10/2016, 05h44   #8
Tidus97
Avatar de Tidus97
slt!
Virus sur l'exe... et c'est pas juste un exe modifié, un virus y est attaché (on peut le virer en le nettoyant). Bref j'ai pas pu tester ms je vois effectivement qu'il y a de nouvelles activations.
Différence entre xprog et xprog-m figeac Programmateur de composant (flasher) 1 13/09/2024 14h45
Quelle version de xprog Maza Programmateur de composant (flasher) 1 05/06/2021 02h11
Installation AK500 Version 1.92 et AK500 PRO version 2.002 + SKC + Base de données BILAUTO Mercedes Benz 16 20/11/2017 21h53
Procédure pour installer DiagBox de la version 7.01 à la version 7.850 zenata LEXIA, PP2000, DiagBox 0 16/11/2017 16h24
mise a jour can clip Version 124 vers Version 125 deedee Renault clip, DDT2000, Nissan consult 3 27/03/2013 20h12
Fuseau horaire GMT +1. Il est actuellement 08h38.
