| Vente, Achat, Echange achat, vente ou echange de matériel, logiciel ...ect passez par ici. |
Pouvoir de réputation: 184 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Vends
RENAULT CAN/K-LINE TOOL Neuf = 560€ livré - avec facture Livré avec Version logiciel V2.49 ![]() EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code) IAW 6R.20 - Read/Write TMS370 EEPROM IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code) VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN KANGOO II (2007-2012) - Key Programming, Change VIN MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN MASTER III (2010-) - Key Programming, Change VIN TWINGO (2007-2013) - Key Programming, Change VIN TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN (NEW!) MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN Dernière modification par diagnosis29 ; 03/03/2016 à 17h51. |
Pouvoir de réputation: 25 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
elle est sortie la version 2.49?
![]() Date d'inscription: février 2014
C est pour ça que je pose la question
Envoyé de mon GOA en utilisant Tapatalk |
Vendu ........
Fondateur
![]() Date d'inscription: novembre 2008
Pouvoir de réputation: 1335 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
🚀 MOD-FILES.COM Service de fichiers Chiptuning Haute Performance Stage 1, 2, 3 | FlexFuel - DPF - EGR - AdBlue - Pop&Bang CLIQUEZ ICI POUR ACCÉDER AU SERVICE 24/7 |
| Outils de la discussion | |
| Renault CAN/K-line ECU Tool | madinina84 | Réparation & Programmation | 19 | 30/11/2023 15h00 |
| recherche Renault CAN/K-line ECU Tool | Gt13turbo | Vente, Achat, Echange | 3 | 26/10/2015 15h23 |
| recherche Renault CAN/K-line ECU Tool | Gt13turbo | Vente, Achat, Echange | 1 | 16/10/2015 21h25 |
| Renault can/k-line tool | opc | Vente, Achat, Echange | 9 | 26/07/2014 22h18 |
| New Maj pp2000 et lexia on line or off line | ramaz | PSA Group Peugeot, Citroën | 10 | 19/11/2011 09h30 |
