Discussion fermée
Vieux 03/03/2016, 16h03   #1
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Par défaut Renault can/k-line tool
Vends
RENAULT CAN/K-LINE TOOL
Neuf = 560€ livré - avec facture
Livré avec Version logiciel V2.49
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
TWINGO (2007-2013) - Key Programming, Change VIN
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN (NEW!)
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
Dernière modification par diagnosis29 ; 03/03/2016 à 17h51.
diagnosis29 est déconnecté
Vieux 03/03/2016, 19h19   #2
foulques
Avatar de foulques
elle est sortie la version 2.49?
foulques est déconnecté
Vieux 03/03/2016, 19h35   #3
samb4064
Avatar de samb4064
Par défaut V2.49
Envoyé par foulques Voir le message
Salut foulques,
Tu sur de ton coup je viens de jeter un coup d'œil il sont toujours à la version v 2.48 pourtant ??
samb4064 est déconnecté
Vieux 03/03/2016, 19h37   #4
foulques
Avatar de foulques
C est pour ça que je pose la question
Envoyé de mon GOA en utilisant Tapatalk
Vieux 03/03/2016, 19h50   #5
diagnosis29
salut ,
Oui j'ai la V2.49 , il n'y a pas de nouvelles fonctions , juste optimisation
a++
Vieux 04/03/2016, 12h36   #6
diagnosis29
Vendu ........
Vieux 04/03/2016, 13h05   #7
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1335
Vendu ........
C'est sûre
🚀 MOD-FILES.COM
Amine-TE est déconnecté
Discussion fermée
Renault CAN/K-line ECU Tool madinina84 Réparation & Programmation 19 30/11/2023 15h00
recherche Renault CAN/K-line ECU Tool Gt13turbo Vente, Achat, Echange 3 26/10/2015 15h23
recherche Renault CAN/K-line ECU Tool Gt13turbo Vente, Achat, Echange 1 16/10/2015 21h25
Renault can/k-line tool opc Vente, Achat, Echange 9 26/07/2014 22h18
New Maj pp2000 et lexia on line or off line ramaz PSA Group Peugeot, Citroën 10 19/11/2011 09h30
Fuseau horaire GMT +1. Il est actuellement 04h13.
