Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 15/11/2015, 19h42   #1
ilirii
Avatar de ilirii
ilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really nice
Par défaut need fast response
where does number 10 wire goes can someone find a wire diagram where it ends and begins where it goes cus i dont have any electricity there +12 so i cant turn up the car no diagnose nothing pls help fast
Type de fichier : jpg ews3_pinout.jpg (95,1 Ko, 28 affichages)
ilirii est déconnecté   Réponse avec citation
Vieux 15/11/2015, 20h30   #2
bahlsen007
Avatar de bahlsen007
bahlsen007 has a spectacular aura aboutbahlsen007 has a spectacular aura about
You should give more details about it like what is the car the year the model and what is your probleme exactly
Un Merci c'est gratuit et ca ne mange pas de pain :)
bahlsen007 est déconnecté   Réponse avec citation
The Following User Says Thank You to bahlsen007 For This Useful Post:
diagnosis29 (15/11/2015)
Vieux 15/11/2015, 20h48   #3
ilirii
Avatar de ilirii
Envoyé par bahlsen007 Voir le message
well its a 136hp e46 1999 i was doing some stuff in that area and i hade that wire opened up i was searching for something then it touched to negative body of the car i hear a clack and no +12 there looked for scanner no dde no abs not a system respondet mounten another ews same took +12 directly from batter nothing so have to find where it ends cus where it starts its ews but where it ends i need looked up the fuses and everything about it nothing all good either the wire is burned or dont know ???????
Vieux 15/11/2015, 21h11   #4
elie
Avatar de elie
elie will become famous soon enough
Salut ,la boite a fusible est dans la boite a gants .
elie est déconnecté   Réponse avec citation
Vieux 15/11/2015, 21h27   #5
ilirii
Avatar de ilirii
Envoyé par elie Voir le message
je deja regarde tout ca va bien je demonte boite a gants tout ok le fil je sepas ou cava aler ce ca que je cherch sorry no good french speaker
Vieux 15/11/2015, 21h36   #6
ilirii
Avatar de ilirii
Vieux 15/11/2015, 22h17   #7
bahlsen007
Check on this site
http://www.bmw-planet.com/diagrams/release/fr/
you have some technic details for bmw and wiring diagram then if you find what you want please come back here for inform us
Vieux 15/11/2015, 22h47   #8
ilirii
Avatar de ilirii
Check on this site
i already looked at this what iam searching is wirediagram where it goes pin 10 to where it goes without me unmouting all the wires in the car to watch where it goes and whats connected to it thanks
Vieux 15/11/2015, 22h57   #9
bahlsen007
Im sorry but i dont have the wiring diagram of the ews module but have you check this :
main*fuse panel: check fuses*9, 22, 27, 29, 30*(ignition switch),*54*(fuel pump), and*14, 49, 67*(EWS).*
Inspect all fuses in the glove compartment if you're dealing with a hard to diagnose no start problem.
-*high amp fuses*above main*fuse panel*(fuseable links).*
There is an 80 amp for the DME and DME main relay, and a*50 amp fuse*for the ignition switch.*
Vieux 15/11/2015, 23h05   #10
ilirii
Avatar de ilirii
i took all the fuse box looked at the small fuses and big ones u know 40 50 amps that are behind looked at fuses near dde ,in the trunk all good but i cant find the trace where that wire goes thats what iam searching for
Vieux 15/11/2015, 23h24   #11
bahlsen007
Have you check the fuse next to the engine?because i see that the pin 10 is the power supply and it comes from the terminal 30 and the terminal 30 is if i dont make mistake next to the engine on the e46
Vieux 15/11/2015, 23h33   #12
ilirii
Avatar de ilirii
iam searching for terminal 30 but there i where are you saying i didnt saw any fuse only a screw and a cable where is the fuse
Vieux 15/11/2015, 23h36   #13
ilirii
Avatar de ilirii
Envoyé par ilirii Voir le message
is it the fuse inside
Type de fichier : jpg m57.jpg (56,8 Ko, 7 affichages)
Vieux 15/11/2015, 23h43   #14
bahlsen007
Yes i think the pin 10 came from this place on the car
Vieux 15/11/2015, 23h56   #15
ilirii
Avatar de ilirii
will look for it tomorow thx
Paul walker est mort (acteur fast and furious) CED300482 Café du forum 11 22/03/2014 23h24
Nissan Fast 05.2012 EL, GL1, CA1, US1 TAGRART Renault, Dacia, Nissan 0 04/09/2012 12h07
Fuseau horaire GMT +1. Il est actuellement 23h12.
