Vieux 09/10/2010, 13h57   #1
skens
Avatar de skens
skens is on a distinguished road
Par défaut Renault Master 2.8 diesel euro 2 dTi! 2000 "SOLVED"
hi
Renault Master 2.8 diesel euro 2 dTi! 2000. turned the lock and does not recognize the key! light blinking 3 x sec. When you give a contact! I found immo box,read 93c46 and post!
could not find the ECU and if it ever does! VIN VF1FDCCL522579915! I put it on the diagnosis! I need a solution to remove the immo pin lights up the car to drive to the workshop!
thx
Speed kills
Dernière modification par skens ; 18/10/2011 à 14h35.
skens est déconnecté   Réponse avec citation
Vieux 11/10/2010, 14h37   #2
skens
Avatar de skens
ECU has not only immo!i
a valve but could not do it! should destroy it and get along a special valve!LUCAS pump!
has only the UCH has a solution immo off?
I do not know the car turns on a pin, has the autodata instructions "read the book the vehicle" but no!
radio remote is not IR!
send dump ,pin 2785!
thx
Speed kills
Vieux 04/11/2010, 14h01   #3
ahmimeda ahmed
Avatar de ahmimeda ahmed
ahmimeda ahmed is on a distinguished road
Par défaut immoff
voici immoff de ton mster
Type de fichier : bin Untited1immoff.bin (128 octets, 36 affichages)
ahmimeda ahmed est déconnecté   Réponse avec citation
Vieux 20/10/2015, 18h22   #4
arnaud_dejard
Avatar de arnaud_dejard
arnaud_dejard is on a distinguished road
hi, this car doesn't have ecu immo, only a coded valve on the pump.
you have to destroy the protection of the valve on the pomp and put a simple valve with 12v on it and it will start.
arnaud_dejard est déconnecté   Réponse avec citation
Euro box 3 sidj Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 6 18/02/2013 22h21
file ori renault master baba Fichiers d'origine, carto, dump, fullbackup 11 26/06/2010 17h56
immo off Renault Master DCI 1.9 slv Immobilizer dumps/solutions 9 08/11/2009 01h07
renault master mehdifree Immobilizer dumps/solutions 1 24/03/2009 23h10
Fuseau horaire GMT +1. Il est actuellement 06h02.
