bonjour a tous
qui a deja eu ce souci? - Malfunction occurred since erasing DTC memory j ai controlle une q5 edc17 et voila ce que je vois... impossible d effacer les defauts. ci-dessous le log merci a tous Establishment diagnostic session with selected unit .... Diagnostic channel is open. Device identification: VAG Number SW: 8R0907401J 0008 VAG Number HW: 8K1907401A H01 System description: 3.0TDI EDC17 Workshop (Part/Imp/Supp): 00000/0000/06335 Vehicle information: Coding: 0121002c240f0120 ID: WAUZZZ8R79A006743 Engine code: CCWA FAZIT identification: FAZIT Identification: BPG-810 14.10.08 1334 0644 ASAM/ODX Identifier: EV_ECM30TDI0118R0907401J 001008 Production Change Number: 15H01--- Workshop System Name (J-number): J623 Flash information: Programming APPLICATION attempts: 2 / 2 / 2 / 2 / 2 Programming APPLICATION successfull: 2 / 2 / 2 / 2 / 2 Flasher info: 30.06.11 98149/0318/01003 48.06.17 98149/0318/01003 Flash status: OK ============================================ 002643 U101700 - ABS brake control module - Read out DTC - Malfunction occurred since erasing DTC memory ============================================ 007144 U100800 - Diagnostic interface for data bus-J533 - Read out DTC - Malfunction occurred since erasing DTC memory ============================================ 008469 002115 - Malfunction occurred since erasing DTC memory ============================================ 005585 0015D1 - active/static - Malfunction occurred since erasing DTC memory ============================================ 018660 0048E4 - Malfunction occurred since erasing DTC memory ============================================ 004814 P056200 - System Voltage - Low Voltage - Malfunction occurred since erasing DTC memory ============================================ 007902 001EDE - Malfunction occurred since erasing DTC memory - Tested in current operating cycle ============================================ 005398 P157200 - Left Electro-Hydraulic Engine Mount Solenoid Valve -N144 - Short circuit to ground - active/static - Malfunction in current or last driving cycle detected - Malfunction occurred since erasing DTC memory - Tested in current operating cycle ============================================ 004978 P067000 - Glow Plug Module Control Circuit - active/static - Malfunction has not occurred in current operating cycle - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory ============================================ 005368 P302C00 - Low heat output relay - Short circuit to ground - active/static - Malfunction has not occurred in current operating cycle - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory ============================================ 005369 P302D00 - High heat output relay - Short circuit to ground - active/static - Malfunction has not occurred in current operating cycle - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory ============================================ 005382 P101500 - Bypass Flap Air Cleaner Valve -N275- - Short circuit to ground - active/static - Malfunction occurred since erasing DTC memory ============================================ 002937 U102600 - Transmission control module - Read out DTC - Malfunction occurred since erasing DTC memory ============================================ 009490 002512 - active/static - Malfunction occurred since erasing DTC memory ============================================ 005301 0014B5 - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory - Tested in current operating cycle - No warning display on ============================================ 007155 001BF3 - Malfunction occurred since erasing DTC memory ============================================ 007157 001BF5 - active/static - Malfunction has not occurred in current operating cycle - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory ============================================ 005507 P202100 - Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 - Low - active/static - Malfunction has not occurred in current operating cycle - Malfunction in current or last driving cycle detected - Not confirmed - Malfunction occurred since erasing DTC memory ============================================ 005608 0015E8 - Malfunction occurred since erasing DTC memory ============================================ 004708 U016400 - Lost Communication With HVAC Control Module - Malfunction occurred since erasing DTC memory ============================================ 004713 U012100 - Lost Communication With - Anti-Lock Brake System (ABS) Control Module - Malfunction occurred since erasing DTC memory ============================================ 004714 U021200 - Lost Communication With Steering Column Control Module - Malfunction occurred since erasing DTC memory ============================================ 004715 U015500 - Lost Communication With - Instrument Panel Cluster (IPC) Control Module - Malfunction occurred since erasing DTC memory ============================================ 004716 U012800 - Lost Communication With Brake System Control Module - Malfunction occurred since erasing DTC memory ============================================ 004719 U014600 - Lost Communication With Gateway "A" - Malfunction occurred since erasing DTC memory ============================================ 004720 U014100 - Lost Communication With Body Control Module "A" - Malfunction occurred since erasing DTC memory ============================================ 005523 P157000 - Engine Control Module (ECM) disabled - Malfunction occurred since erasing DTC memory ============================================ 004629 P068A00 - ECM/PCM Power Relay De-Energized Performance - Too Early - Malfunction occurred since erasing DTC memory ============================================ 005307 0014BB - Malfunction in current or last driving cycle detected - Malfunction occurred since erasing DTC memory ============================================ |
![]() Date d'inscription: août 2009
Salut c'est une histoire de protection du calculo,ya une lecture sur table en bootmode qui a été fait?
+1 Smart057,
il semble qu'il y ait une lecture/ecriture de l'ECU et qu'il soit désormais bloqué. Y a t il eu manipulation de cet ECU? |
| diagbox - internal communication error has occurred | breakli | LEXIA, PP2000, DiagBox | 9 | 30/10/2020 01h26 |
| program Flash Memory | misterixion | Informatique | 1 | 10/04/2015 23h08 |
| Q Flash memory effacer/reprogrammer | benaknoun | Programmateur de composant (flasher) | 0 | 01/11/2009 03h35 |
