Vieux 05/06/2015, 11h42   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Par défaut display safe sur opel corsa
bonjour les membres j ai un probleme sur opel corsa 2006 essence quand j allume le poste radio tout fonctione nikel apres quelque seconde j ai le message display safe sur l afficheur de tdb je cherche comment sortir de ce mode safe et merci
l union fait la force
Vieux 05/06/2015, 12h47   #2
Ecomouv
Avatar de Ecomouv
Ecomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud of
salut , ta radio continu de fonctionner?
Ecomouv est déconnecté   Réponse avec citation
The Following User Says Thank You to Ecomouv For This Useful Post:
electro_bordeaux1 (05/06/2015)
Vieux 05/06/2015, 13h38   #3
electro_bordeaux1
non pas de bip que l apparition du message sur le tdb display safe
Vieux 05/06/2015, 20h01   #4
Ecomouv
Avatar de Ecomouv
Salut , tu as quelque chose pour entrer dans l'autoradio ( ehu) et dans l'afficheur ( mid) ? Tu as seulement display safe ou il y a aussi radio safe ? Dans la voiture , il y a le CARpass ? C'est une catre avec code imo , cod key , radio code ...
electro_bordeaux1 (06/06/2015)
Vieux 05/06/2015, 20h41   #5
MecaTech
Banned
Avatar de MecaTech
MecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond repute
MecaTech est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to MecaTech For This Useful Post:
electro_bordeaux1 (06/06/2015), obdauto2 (07/06/2015)
Vieux 06/06/2015, 18h24   #6
electro_bordeaux1
Envoyé par Ecomouv Voir le message
il y a que display safe sur le tdb et l autoradio fonctione nikel
Vieux 06/06/2015, 18h44   #7
salut, j'ai un prob similaire sur un vivaro de 2005 1.9 cdti, suite a une batterie a plat !
ils ont cablé a l'envers !! résultat l'alternateur a grillé, beaucoup de fusibles ont sauté
aprés remplacement de l'alternateur, et modif du pole + car il y a une sécurité sur le gros + de la batterie, qui as fondu, j'ai ajouter un fusible 225 A en remplacement pour eviter de changer tout le faisceau, c pas fournit seul!
après tout cà, j'ai pas de rétro, pas d'afficheur, pas de radio,
les fusibles ont sautés , sur le support fusibles et aussi sur l'auto radio : maintenant j'ai tout mais pour la radio, j'ai SAFE qui s'affiche pas moyen d'entrer 1 code, faut t'il attendre ?? pour qu'il propose d'entrer le code ??
edit correction , fusible noir 225A et pas 125 A
Dernière modification par jphp ; 07/06/2015 à 13h40.
Vieux 06/06/2015, 19h29   #8
MecaTech
Banned
Avatar de MecaTech
1) Mettre le contact avec Autoradio éteint
2) Appuie sur " AS " puis enfonce le bouton " ON/OFF " de l'autoradio
3) Il devrait sortir du " SAFE MODE " et te demander le code là tu aura le symbole suivant ----
4) Maintenant si tu as le code sécurité de l'autoradio avec les touches 1, 2 , 3 , 4 inscrit le code
5) Puis valide en restant appuyer sur " AS " relâche " AS " quand tu va entendre un bip
6) Là normalement ton autoradio est OK
INFO:
Si après 10 essai tu as bloqué l'autoradio, laisse l'autoradio allumer il va débloquer seul patience
Dernière modification par MecaTech ; 06/06/2015 à 19h31.
The Following 3 Users Say Thank You to MecaTech For This Useful Post:
electro_bordeaux1 (06/06/2015), jphp (06/06/2015), obdauto2 (07/06/2015)
Vieux 07/06/2015, 08h28   #9
Ecomouv
Avatar de Ecomouv
Envoyé par electro_bordeaux1 Voir le message
Salut , tu as une interface pour intéroger le display ( Mid ) ? C'est peut-etre un probleme de liaison ou parametrage entre ta radio et ton afficheur . Les stations s'affiches ?
electro_bordeaux1 (08/06/2015)
Vieux 08/06/2015, 12h10   #10
electro_bordeaux1
j ai l opcom come outil de diag j aimerais bien savoir la procedure a suivre et merci
Vieux 08/06/2015, 20h32   #11
Ecomouv
Avatar de Ecomouv
Salut , je te laisse traduire pour éviter les erreurs . Si ca peut t'aider ....
Ecco come gestire una situazione di "Display Safe" della vostra corsa, questa guida ha funzionato nel mio caso, non mi ritengo responsabile di eventuali danni causati da errori.
La procedura è molto semplice:
Premessa:
Per poter accoppiare un display ed una autoradio almeno l'autoradio deve essere "vergine"; qualora non fosse così, è opportuno prima "sprogrammare" EHU (Autoradio) e DIS (Display) appaiati per poi "programmare" la nuova coppia.
Prima di iniziare leggete tutti i passi qui sotto elencati
La procedura per il disaccoppiamento:
1) Collegare l'interfaccia (op-com, tech2) alla macchina, il quadro è meglio tenerlo accesso
2) Selezionare il modello di macchina corretto. Es: 2009 - Corsa D
3) Body - Infotainment System - DIS - Programming
a) Inserire il codice di sicurezza (quello di 4 cifre che vi hanno dato con la macchina, non quello dell'autoradio)
b) Scegliere "Disable anti-hijack"
4) Body - Infotainment System - EHU - Programming
5) A questo punto se accendete la radio questa inizierà a beeppare chiedendovi di inserire il codice di sicurezza: significa che avete fatto la procedura corretta
6) Togliere la chiave dal quadro (per sicurezza, non è fondamentale)
7) Scollegare l'interfaccia col PC
Sostituzione del display:
8) Per lo smontaggio facciamo riferimento a questa guida che è fatta benissimo, è utile per noi la parte relativa al display
9) Collegare il nuovo display, ma prima di rimontare il tutto continuiamo con i passi per verficare che vada tutto. Potete appoggiarlo senza aver paura
La procedura per l'accoppiamento:
10) Ricollegate l'interfaccia e inserire nuovamente le chiavi nel cruscotto accendendo il quadro. Il display segnalerà "Display Safe", l'autoradio chiederà "CODE" e bipperà.
11) Riselezionate il vostro modello di macchina
12) Body - Infotainment System - DIS
13) Qui potrebbe chiedervi, mostrandovi semplicemente una lista, "ma quale display è questo"? Non fatevi prendere dal panico, serve solo per riempire correttamente i menu relativi ai rilevamenti dei dati, in ogni caso selezionate quello che più si avvicina al vostro (dietro il GID c'è l'etichetta col codice, es VDO4410).
14) Dopo non esservi fatti prendere dal panico dal punto precedente (ripeto che non inficia la procedura) o se non avete avuto scelta, selezionare
Programming
15) Inserire il codice di sicurezza
16) Scegliere "Enable anti-hijack"
17) Inserire il codice (autoradio)
18) Body - Infotainment System - EHU - Programming
b) Scegliere "Enable anti-hijack"
c) Inserire il codice (autoradio)
19) Uscite da tutto, spegnete il quadro, scollegate il pc, accendere il quadro e radio, a questo punto dovrebbe andare tutto, senza problemi.
Per impostare l'ora se non avete i tasti bc ed ok:
20) Body - Infotainment System - DIS - Programming - Set Time
21) Impostate l'ora e la data.
Ed ecco quello che potrete vedere, questo display non è di una corsa D, è di una Meriva. Non ho l'autoradio con le 4 frecce quindi non riesco a cambiare le unità di misura ne la lingua, appena ho tempo provo a "smanettare" ancora un pochino per risolvere il problema.
Se il vostro è per la CORSA D e se avete autoriadio giusta allora siete a posto
22) Se siete soddisfatti del vostro lavoro rimontate tutto -> Fine
electro_bordeaux1 (20/12/2017)
opel corsa c nimbus Transponder, code pin 1 12/02/2015 07h32
Opel corsa Auto16 Transponder, code pin 0 18/06/2014 13h50
opel cd30 display safe massiniss Autoradio et Navigateur GPS 3 13/06/2012 14h38
opel corsa 1.7 dti Youcef-ouk Opel-Vauxhall, Saab 2 22/09/2011 21h50
opel corsa memati Tableau de bord (Dashboard) 5 02/04/2011 18h43
Fuseau horaire GMT +1. Il est actuellement 20h06.
