Vieux 14/10/2014, 20h41   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut vcds code acces
Bonsoir a tous je voulez savoir ou je pourrai trouver les code accès sécurité (fonction 16) des calculateur
Verdun est déconnecté   Réponse avec citation
The Following User Says Thank You to Verdun For This Useful Post:
COTECH00 (19/10/2014)
Vieux 14/10/2014, 21h00   #2
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Envoyé par Verdun Voir le message
Regarde ici :
http://www.google.fr/search?site=&so....3.BqbM425aLcw
Premier lien.
___________________________
www.123diagauto.com
The Following 7 Users Say Thank You to diagnosis29 For This Useful Post:
diagprog (15/10/2014), electro_bordeaux1 (15/10/2014), ErrorBinary (14/10/2014), mbn30 (15/10/2014), msirdi-31 (09/01/2020), smail djounadi (31/01/2015), Verdun (14/10/2014)
Vieux 14/10/2014, 23h56   #3
Verdun
Avatar de Verdun
merci j ai regarder mais je trouve pas exemple pour calculateur d airbag d une tiguan annee 2007 et calculateur airbag audi a3 2006
Vieux 15/10/2014, 13h23   #4
diagnosis29
VW Tiguan (5N) Airbag VW10
Adaptation
Used to deactivate individual airbag components (see repair manual for details).
Basic Setting
Seat Occupied Recognition Control Module (J706)
If the Seat Occupied Recognition Control Module (J706) or the seat itself have been replaced, the basic setting has to be performed.
[Select]
[15 - Airbags]
[Security Access - 16]
Enter 10522, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The reset has been performed.
[Done, Go Back]
[Close Controller, Go Back - 06]
Special Procedures
Seat Occupied Recognition Control Module (J706): Reset
If a repair on the Seat Occupied Recognition has been performed, a reset has to be performed too.
Prerequisites:
Seat in normal position.
Seat must NOT be occupied during the whole procedure.
Seatbelt must NOT be plugged in.
No faults in the system.
Interior temperature must be between 0 °C and 37 °C (32 °F and 98 °F).
[Select]
[15 - Airbags]
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[Save]
[Done, Go Back]
Audi A3 (8P) Airbag 9.41
[Select]
[15 - Airbags]
Enter 30475, to enable the basic setting.
If you are having problems performing this security access, contact us.
[Do it!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Special Procedures
Prerequisites:
[Select]
[15 - Airbags]
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[Save]
[Done, Go Back]
source : http://wiki.ross-tech.com/wiki/index.php/Main_Page
www.123diagauto.com
Dernière modification par diagnosis29 ; 15/10/2014 à 13h27.
The Following 6 Users Say Thank You to diagnosis29 For This Useful Post:
diagprog (15/10/2014), domidom (24/10/2014), Draag0 (27/01/2015), jah83 (27/12/2014), natouss225 (16/10/2014), Verdun (15/10/2014)
Code sécurité VCDS Audi A4 B8 Breizhelec VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 3 13/08/2016 16h28
Code accès PP2000 ??? MICHOU13 LEXIA, PP2000, DiagBox 3 06/02/2014 00h25
code d acces pour apprentissage cle electro_bordeaux1 programmation & synchronisation de clé 17 06/01/2014 21h53
Fuseau horaire GMT +1. Il est actuellement 15h51.
