Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 16/06/2013, 06h49   #1
cairo_gsm
Avatar de cairo_gsm
cairo_gsm is an unknown quantity at this point
Par défaut ECU code
Hi, I change my car ECU to used one bosch 06f 906 056 this ECU was used on bora 2005 automatic car, my car caddy life 2011 manual , how I can decode this ECU to work with manual transmitter as I have many problems for this , thnx
cairo_gsm est déconnecté   Réponse avec citation
The Following User Says Thank You to cairo_gsm For This Useful Post:
dhdesigner (24/04/2015)
Vieux 16/06/2013, 07h16   #2
cairo_gsm
Avatar de cairo_gsm
by the way I can easy read the EEPROM from this ECU if this can help
Vieux 19/11/2013, 08h24   #3
Daniulis
Avatar de Daniulis
Daniulis is an unknown quantity at this point
Post part number of the original one, then I could tell you are they fit each other.
Daniulis est déconnecté   Réponse avec citation
Vieux 25/02/2014, 12h14   #4
dib47
Avatar de dib47
dib47 is an unknown quantity at this point
What was wrong with the original ecu ??
Can you pull original dump & flash from original to put in new ecu ?
If this doen't work then ecu is not compatable
dib47 est déconnecté   Réponse avec citation
Vieux 26/02/2014, 20h12   #5
majo
Avatar de majo
majo is an unknown quantity at this point
you can use otockeck soft to read code
majo est déconnecté   Réponse avec citation
Vieux 19/03/2014, 10h51   #6
MadPilot
Avatar de MadPilot
MadPilot is on a distinguished road
Recoding ECU needed. I useing VCDS. Read coding in old ECU and write to new.
MadPilot est déconnecté   Réponse avec citation
Vieux 02/04/2015, 11h44   #7
fifii69
Avatar de fifii69
fifii69 is on a distinguished road
You have a few different way to do it, you can desolder eeprom+flash , you can clone it use bdm , you can do adaptation in vcds, those all way will work only if ECUs hardware are same...
fifii69 est déconnecté   Réponse avec citation
Vieux 23/05/2015, 16h16   #8
westmanpt
Avatar de westmanpt
westmanpt is on a distinguished road
dont think a 2005 ecu will be same as 2011... as long they apear similar i really dont think hardware will be the same. what is the real problem with your caddy's ecu?
westmanpt est déconnecté   Réponse avec citation
The Following User Says Thank You to westmanpt For This Useful Post:
markello (24/05/2015)
Vieux 24/05/2015, 17h25   #9
markello
Avatar de markello
markello is an unknown quantity at this point
Agree with @Westmanpt@ ECU will not be the same
markello est déconnecté   Réponse avec citation
Vieux 19/06/2015, 11h57   #10
pecirepi
Avatar de pecirepi
pecirepi is an unknown quantity at this point
you have few options.
to check ecu type edc16u1, u31 ...
if same type of ecu then you have options to make clone of your ecu to new used ecu, with this option you will solve all problems with coding and other stuff. but for this option you need to have tool which can clone that type of ecu.
next thing is to send here eeprom from old ecu and new ecu, so we can check ecus.
third thing is to disable immo in eeprom and to use vcds and to read original codings from old ecu and to recode new ecu with original numbers.
it is up to you to decide and to told us what kind of tools you have so we can help you.
Ivan Pecirep
pecirepi est déconnecté   Réponse avec citation
Vieux 17/10/2015, 09h43   #11
piranha--
Avatar de piranha--
piranha-- is an unknown quantity at this point
05-11 ecu will be cpmpletly different.
did ypu try code with vcds?
piranha-- est déconnecté   Réponse avec citation
Vieux 21/10/2015, 11h06   #12
simon932
Avatar de simon932
simon932 is an unknown quantity at this point
Buy the correct driver (year) and re-code VCDS ;)
simon932 est déconnecté   Réponse avec citation
Vieux 24/10/2015, 15h49   #13
carpin
Avatar de carpin
carpin is an unknown quantity at this point
Envoyé par simon932 Voir le message
cairo_gsm has to buy the vcds or vag com profesional tool
And this message is very old
carpin est déconnecté   Réponse avec citation
Fuseau horaire GMT +1. Il est actuellement 21h45.
