Vieux 03/12/2009, 02h17   #1
milerk
Avatar de milerk
milerk is an unknown quantity at this point
Par défaut help motronic 7.5.30
I wish to comment on you is the problem I have with the vehicle
all started giving you boot with the low battery
light of the dashboard immovilizador shuts down and the key it recognizes well chek engine light not appears me
the ecu has all feeds well and the cabling this also electrical well not I talk with the ecu with the vag with thought undo or virginizar the ecu eeprom to see what happens
the vehicle is a trends gol
thank you for your help
milerk est déconnecté   Réponse avec citation
Vieux 03/12/2009, 14h04   #2
alqaheri
Avatar de alqaheri
alqaheri is an unknown quantity at this point
This car has Gateway?
Check the faults of the gateway, if you can post a full scan this will help.
For me it looks like faulty ECU.
Your ECU is Bosch and the Vag number ends with 032?
Thank you
____________________________
Ecu Commander Studio®
Web: [url]www.ecucommander.com[/url]
alqaheri est déconnecté   Réponse avec citation
Vieux 04/12/2009, 02h09   #3
milerk
Avatar de milerk
Par défaut Motronic
ALQAHERI
Thank you for your reply
the ecu is a motronic 0261 So4 100
vag number 032 906 032 BJ
and the eeprom file is that
I am not sending more data because not
I can talk with the ecu lines of communication are well and feeds are ok
thank you
Vieux 04/12/2009, 13h55   #4
alqaheri
Avatar de alqaheri
If you can communicate with the ECU then there is an immo problem
In this case, open the ecu, you will find eeprom 95040, read it and post it here.
If you can't communicate with the ecu, then check the gateway or the Dash Panel Insert.
Post a full scan here if possible
motronic 7.5.30 immo milerk Immobilizer dumps/solutions 2 27/11/2009 23h12
Fuseau horaire GMT +1. Il est actuellement 09h59.
