| Airbag Questions et réponse pour vos problèmes avec la sécurité passive airbag. |
Hi,
I've got a problem to clean this module, I've tried to used mine clean dumps, but the light stills on and it doesn't appears no error in the diagnostic. Can anyone send me a dump for this crash: AUTOLIV 602327300 9652275980 2004 (year) eep 95080 thanks Hugo Pinho |
| The Following User Says Thank You to hugopinho For This Useful Post: | Fouadtl (11/06/2023) |
![]() Date d'inscription: décembre 2008
Pouvoir de réputation: 21 ![]() ![]() ![]() ![]() |
try this !
thanks!
I will test it and then I report. hugopinho |
friend,
I've verify both, and they are equal to mines. It does't appears any error in diagnose, but the light doesn't turn off. thanks again |
Pouvoir de réputation: 19 ![]() |
Try to have look at parameters, and check whether resistances are good or high.
| The Following User Says Thank You to Amine13 For This Useful Post: | Fouadtl (11/06/2023) |
hi,
At parameters it appears absence of switch on/off and belt pretensor |
so, in this case, it may be a configuration problem, so go to configuration, and check whether all components are PRESENT, at least those present in the car...
Hi
I've tryed both dumps from the tachsoft 6.4 and the airbag light is always on. It doesn't have any fault code. The Unit is not blocked with diag, but in The configuration it apears the following: conductor airbag - present passenger airbag - present Pretensers - absent switch on/off for the passenger - absent. And it doesn't let me configurate it. Does anyone had a problem like this? Thank you all |
try to paste th ORIGINAL airbag dump and get into configuration, using a clip renault will be better....
#10 |
Banned
salut j'ai le meme probleme sur ma voiture 206 car j'ai perdus ds trasse sur ma carte autoliv apres une penetration d'eau dans la boite apres j'ais constaté que les 2 voiyant airbag reste alumer mais j'ai recuperer une autre boite autolive a 4 voix j'ai enlever le flash et l'eeprom 95080 de ma boite d'origine et je les souder sur l'autre boite recuperer j'ais ramener ma voiture chezun electricien qui possede pps je l'ais programmer le deuziemme voiyant c'est eitin le'autre reste alumer quoi faire merci
| The Following User Says Thank You to mounirflash For This Useful Post: | Fouadtl (11/06/2023) |
#11 |
salut, envoi ton dump.
| The Following User Says Thank You to ptitom33 For This Useful Post: | Fouadtl (11/06/2023) |
#12 |
Banned
voila le fichier dump je l'avais lis avec topmax
#13 |
donne moi les ref de ton boitier.
| The Following 2 Users Say Thank You to ptitom33 For This Useful Post: | Fouadtl (11/06/2023), mounirflash (19/01/2012) |
#14 |
voici pour toi @+ |
| The Following 2 Users Say Thank You to crenshaw For This Useful Post: | Fouadtl (11/06/2023), mounirflash (05/01/2012) |
| clear airbag peugeot 207 | hugopinho | Airbag | 4 | 22/11/2009 21h27 |
| clear 207 airbag | everson29 | Airbag | 16 | 04/10/2009 10h23 |
| Peugeot expert clear dump | LphantMan | Airbag | 1 | 18/08/2009 22h55 |
| Airbag clear tigra temic | tuareg | Airbag | 1 | 17/07/2009 20h03 |
| Nissan Sentra 2006 Clear Airbag ECU | SSOMSergey | Airbag | 1 | 19/02/2009 22h39 |
