![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BMW Road Map Northern Africa NEXT 2022
Coverage: Algeria, Egypt, Morocco, Tunisia Compatibility (Headunit NBT): BMW/Mini Cooper F01, F02, F03 ab 07/2012- F06 ab 03/2013- F07 ab 07/2012- F10,F11 ab 09/2012- F12,F13 ab 03/2013- F15 ab 08/2013- F18 ab 09/2012- F20, F21, F34 ab 03/2013- F22,F33 ab 11/2013- F25 ab 04/2013- F26 ab 04/2014- F30, F31 ab 11/2012- F32 ab 07/2013- F35 ab 01/2013- F36, F80 , F82 ab 03/2014- F56 ab 11/2013- I01 ab 09/2013- I12 ab 12/2013- ![]() Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
bonjour, comment obtenir le fichier ?
Hello, everything is written in the description my friend.
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
The link was updated
Link without pass
BMW Road Map Northern Africa NEXT: Complete NBT Navigation Map Update
WHAT INSIDE: NorthAfricaNEXT2022.tar OFFICIALLY SUPPORTED VEHICLES & PRODUCTION DATES (BMW ROAD MAP NORTHERN AFRICA NEXT 2022) Important Technical & Regional Note: Compatible STRICTLY with BMW and MINI vehicles factory-equipped with the NBT (CIC-HIGH / ID4) head unit and Option S609A (Navigation System Professional / MINI Navigation XL, 8.8" or 10.25" display). - OFFICIAL COUNTRY COVERAGE: Strictly 4 countries — Algeria, Egypt, Morocco, and Tunisia (Libya, Mauritania, and Sudan are NOT included; GCC/Gulf states require "Middle East NEXT", and Sub-Saharan/South Africa requires "Southern Africa NEXT"). - ALWAYS check your iDrive menu BEFORE downloading (Navigation -> Options/Settings -> Navigation System Version) to confirm your current map explicitly contains the word "NEXT". - NOT COMPATIBLE with older CIC ("PREMIUM"), CHAMP2 ("MOVE"), EntryNav ("ROUTE" — used on base 6.5" screens and ALL factory X1 F48 / 2 Series F45/F46 models), or newer 2015/2016+ NBT EVO ("EVO") systems. - USB & FSC Requirement: Installs via a FAT32- or exFAT-formatted 16GB/32GB/64GB USB flash drive. Map data files only — vehicles without an active Lifetime FSC will require a valid VIN-specific 20-digit NEXT FSC activation code. 1. BMW F-SERIES & I-SERIES (FACTORY NBT S609A PRODUCTION WINDOWS) - 1 Series: F20 5-Door & F21 3-Door (03/2013 – 03/2015; 03/2015+ LCI switched to "EVO"). - 2 Series: F22 Coupe (11/2013 – 03/2015), F23 Convertible (11/2014 – 03/2015). (F45/F46 Active/Gran Tourer use ROUTE/WAY and are NOT compatible). - 3 Series & M3: F30 Sedan (11/2012 – 07/2015), F31 Touring (07/2012 – 07/2015), F34 Gran Turismo (03/2013 – 07/2015), F35 LWB Sedan (01/2013 – 07/2015), F80 M3 (03/2014 – 07/2015; 07/2015+ switched to "EVO"). - 4 Series & M4: F32 Coupe (07/2013 – 07/2015), F33 Convertible (11/2013 – 07/2015), F36 Gran Coupe (03/2014 – 07/2015), F82 / F83 M4 (03/2014 – 07/2015). - 5 Series & M5: F07 Gran Turismo (07/2012 – 02/2017), F10 Sedan (09/2012 – 10/2016), F11 Touring (09/2012 – 02/2017), F18 LWB Sedan (09/2012 – 09/2016), F10 M5 (09/2012 – 12/2016). - 6 Series & M6: F06 Gran Coupe, F12 Convertible & F13 Coupe (03/2013 – 03/2016; pre-03/2013 uses "PREMIUM", 03/2016+ uses "EVO"). - 7 Series: F01, F02, F03 & F04 ActiveHybrid 7 LCI (07/2012 – 06/2015). - X Series SUVs: X3 F25 (04/2013 – 03/2016), X4 F26 (04/2014 – 03/2016), X5 F15 (08/2013 – 07/2016), X6 F16 (08/2014 – 07/2016), X5M F85 & X6M F86 (12/2014 – 07/2016; 08/2016+ switched to "EVO"). - BMW i-Series: i3 I01 (09/2013 – 11/2017, strictly with Option S609A Professional), i8 I12 (12/2013 – 03/2018). 2. MINI F-SERIES (FACTORY NBT NAVIGATION XL — 8.8" DISPLAY) - MINI Hatch, Clubman & Convertible: F56 3-Door (11/2013 – 11/2016), F55 5-Door (09/2014 – 11/2016), F54 Clubman (11/2015 – 11/2016), F57 Convertible (03/2016 – 11/2016) — strictly vehicles equipped with the 8.8" Professional / Navigation XL NBT system showing "NEXT" in the version menu (base 6.5" screens use ROUTE/MOVE). 3. USER-CONFIRMED IMPORT CONVERSIONS & RETROFIT NOTES (BIMMERPOST / MHH AUTO / CARTECHNOLOGY) Based on verified feedback from BMW specialists and owners in Egypt, Morocco, Algeria, and Tunisia: - European, US & GCC Imports (Region Coding Required): Owners confirm that BMWs imported into Northern Africa from Europe, North America, or Gulf/UAE markets (originally factory-loaded with "Europe NEXT", "North America NEXT", or "Middle East NEXT") require NBT region coding to Northern Africa + a Northern Africa NEXT FSC code before USB installation. - NBT Retrofitted Vehicles: Confirmed working on older BMW E-Series (E60, E70, E90, E92) and early 2010–2012 F-Series (F01, F10, F20, F25, F30) upgraded with a retrofitted NBT NEXT head unit. PACK FEATURES, COVERAGE & INSTALLATION NOTES: - Official 4-Country Coverage: Includes the road network, highway interchanges, speed limits, and Points of Interest (POI: fuel stations, hotels, ATMs, restaurants, and service centers) strictly for Algeria, Egypt, Morocco, and Tunisia (Libya, Mauritania, and Sudan are excluded). - Final Official NBT Release: Remains the final official Northern Africa map release for the NBT (NEXT) platform (subsequent 2023–2025 regional updates were released exclusively for newer EVO and WAY systems). - 2015–2016 Factory Cutoff Clarification: Open-ended start dates listed in legacy catalogs apply only up to mid-2015 / early 2016, when BMW switched production on those chassis from standard NBT to NBT EVO ("EVO" maps). - USB Installation & 20-Digit FSC Activation: Extract directly to the root of a 16GB–32GB USB drive (FAT32 or exFAT — NBT supports both formats) and install via the main USB port in the center armrest in approximately 15–25 minutes. Standard NBT units accept a 20-digit VIN-specific FSC code generated via ENET cable without complex software patches. DESCRIPTION: BMW Road Map Northern Africa NEXT is the final official factory cartographic database release (not a standalone PC program) designed to update factory-installed NBT (CIC-HIGH / ID4) Navigation System Professional head units in compatible BMW and MINI vehicles. ![]() Need it? Push button Thanks, PM for pass | or by email right now.
| BMW Road Map Europe EVO 2022-1 | Aleksey-MS | BMW, Mini, Rolls-Royce | 8 | 21/11/2026 14h30 |
| BMW Road Map Europe Live 2022-1 | Aleksey-MS | BMW, Mini, Rolls-Royce | 30 | 21/11/2026 14h29 |
| BMW Road Map Europe ROUTE East + West 2022-2 (without pass) | Aleksey-MS | BMW, Mini, Rolls-Royce | 4 | 27/05/2024 10h08 |
| Fsc Road Map Europe BMW | Scorpium59 | Vente, Achat, Echange | 3 | 02/07/2022 21h14 |
