Précédent   Tlemcen Car electronics > Outils & Diag > Agricultures / Construction > Cummins
Vieux 09/04/2026, 23h34   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Arrow Cummins Calterm + Metafiles
Cummins Calterm 5.16
It's an engineering program for advanced tuning of Cummins engine ECUs. Unlike standard dealer scanners, it allows you to modify hidden factory calibrations: remove power and speed limits, and disable emissions control systems (EGR, DPF, SCR).
Why are metafiles (.ecfg / .ecf) needed?
These are configuration “translation maps” for a specific firmware version. Calterm will not work without them. They are needed for:
Navigation: they specify the exact address of the desired parameter in the ECU’s memory.
Decoding: converting raw machine code into human-readable text labels.
Conversion: translating numerical values into physical quantities (RPM, bar, degrees).
Conclusion:
without the correct metafile, Calterm simply won’t understand the ECU’s data structure and won’t allow you to read or change settings.
Need it? Push button Thanks, PM for pass | or by email right now.
Type de fichier : txt Cummins Calterm + Metafiles new.txt (34 octets, 1 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following User Says Thank You to Aleksey-MS For This Useful Post:
zourson (17/11/2026)
Vieux 10/09/2026, 16h24   #2
Aleksey-MS
Cummins Calterm 5.16 + MetaFiles
Conversion: translating numerical values into ****** physical quantities (RPM, bar, degrees).
Conclusion:
Full list of updated metafiles
Cummins Insite 8.8. 8.7, 8.5.2 - Mega + Cummins Incal (without pass) Aleksey-MS Cummins 18 12/11/2026 15h46
Cummins Calterm 4.7 et MetaFiles mod-files.com Cummins 0 28/09/2025 22h52
Cummins Calterm 5.3 (juste programmer sans activation) - Mega Aleksey-MS Cummins 14 22/02/2025 14h58
Cummins Calterm 4.7 et MetaFiles mod-files.com Cummins 0 15/02/2020 12h35
Calterm 3.8 + kg +instructions mod-files.com Caterpillar 1 02/04/2017 08h19
Fuseau horaire GMT +1. Il est actuellement 02h16.
