Afficher un message
Vieux 03/08/2022, 19h49   #1
Aleksey-MS
Avatar de Aleksey-MS
Aleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant futureAleksey-MS has a brilliant future
Par défaut Cummins InPower Pro 14 (installation files)
InPower provides the following functions for monitored equipment:
• Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls; For details on devices supported refer Technical Details tab.
• Allows the monitored equipment to send alarm information to a connected computer.
• Configurable for units of measurement, and level of user access (read only, read/change values, administrator).
• Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points and other values.
• Convenient programming of configurable inputs in the controllers.
• Viewing of equipment history, fault codes, and data associated with fault codes.
• Generates reports of monitored data
• Allows released firmware upgrades on Power Command genset controls.
• Plot critical parameters in a strip chart format, and export data to 3rd party software tools for manipulation and viewing.
• Simulate fault conditions in genset controls in compliance to NFPA 110 requirements to demonstrate functionality of the controller and monitoring equipment in a facility.
Type de fichier : txt Cummins InPower Pro.txt (54 octets, 1 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following User Says Thank You to Aleksey-MS For This Useful Post:
darkboybeyond (02/12/2023)
