Tlemcen Car electronics (https://www.tlemcen-electronic.com/forum/index.php)
-   Mécanique générale (https://www.tlemcen-electronic.com/forum/forumdisplay.php?f=38)
-   -   depanne (https://www.tlemcen-electronic.com/forum/showthread.php?t=31980)
hachemi 23/09/2014 14h04
depanne
bonjour jai ma chevrolt qui melange lessence avec huille et je sait pas dous vien se problem ma chevrolet sparck 2007
maitre_flav 23/09/2014 16h14
Comment t'aperçois tu que tu as un mélange huile essence ?
Ou est situé ton circuit et ta rampe d'injection , dans le cache culbu ou en extérieure ?
don3imad 29/09/2014 14h25
Did you change your fuel pump??
because if you had trouble installing the fuel pump.. and i am hoping you used a new one.. it could be leaking internally.. filling the oil pan with almost gravity feed from the fuel tank..
How could thid happen?? ok, the feul pump has 2 valves inside and one spring loaded diaphragm, So when the diaphragm is pulled up.. the fuel is pulled thru the inlet check valve filling the cavity.. as the diaphragm is released spring pressure pushes down with enough force to create about 5 pounds of fuel pressure. this pushes fuel thru the output check valve.
That's why if the diaphragm is damaged during install.. the fuel can leak into the engine under some conditions.. there is a vent hole on the side of the pump to prevent this.. but it can happen..
Maybe i make it more complicated for you, but it's just to show you how could a damaged fuel pump can cause your problem.
Best Regards
benaflek2 09/10/2014 22h44
Oui, c'est a quelle niveau que tu t’aperçois du mélange?
Une segmentation Hs ou un injecteur qui pisse peu rincer l'huile aussi.
Fuseau horaire GMT +1. Il est actuellement 06h55.
