Tlemcen Car electronics (https://www.tlemcen-electronic.com/forum/index.php)
-   PSA Group Peugeot, Citroën (https://www.tlemcen-electronic.com/forum/forumdisplay.php?f=42)
-   -   307 BSI need virgin dump (https://www.tlemcen-electronic.com/forum/showthread.php?t=1151)
t77 21/06/2009 15h12
Hi,my friend i'm new in this forum,i'm glad to talk with you,i want replace bad bsi in peugeot 307 1,6HDI 2005 I have found used bsi and writed ST95128,with virgin file,but when i start pps insert vin,pin code,and it tell me:bsi can't start program,please help,me.thanks.
Amine-TE 21/06/2009 15h47
maybe you are using bad virgin file.
t77 21/06/2009 16h51
ok this is my virgin dump
Amine-TE 21/06/2009 18h00
i don't think that's virgin !
t77 21/06/2009 18h16
Hi again ,i have question for you,maybe you have a virgin dump for my BSI ,i have many software and dumps for exchange ,maybe you need somthing.Regards t77
Amine-TE 21/06/2009 18h18
no, beleive me i don't have for that model,
i check with others virgin dump and it appear like not ok !!!
is just for that i told you that's not ok !
t77 21/06/2009 18h23
Ok thanks for quickly reply.Now i know thats i must search for good dumps .
Thank You.
Mrpromega 24/06/2009 02h17
Hi !
Sorry but your dump remains not virgin
The details refering to your dump :
VIN : VF33HRHR 9310(x)187
& the PIN refering is : QC(x)T
So, here you are what are you seeking for !
Pass on PM, Best regards:41:!
t77 26/06/2009 17h11
Thanks of lot Mrpromega for this dump i will be try use it.
Mrpromega 26/06/2009 17h24
Welcome
give us the result, Best regards !
t77 11/08/2009 00h38
Ok today I was programmed your dump of BSI and car started. This dump really work after configuration....Many thanx Mrpromega for help. U are GREAT.
Best Regards
Mrpromega 11/08/2009 01h19
Welcome again
Best regards ...:coolgleamA:
msv81 13/08/2009 17h27
Hello, I have troubles with engine starting on Peugeot 307 2.0 HDI 66kW 90hp (DW10TD) 2002 year.
It seems that immo blocks engine. Can comebody help me with fixing ecu and bsi dumps?
ECU: siemens 93c56
BSI: 912dg128
See original files in attachment.
t77 14/08/2009 08h04
Hello write more about what happens with BSI and ECU? Bsi is VALEO? ECU siemens number please.
Regards
msv81 14/08/2009 12h52
Envoyé par t77 (Message 8754)
Regards
Battery was completely discharged (the reason was in generator set belt). I've took power from another auto to start engine. Everything was fine. Then I had a short trip (about 1 km), stopped engine, disconnected and charged battery. Then I connected battery again, but after that immo indicator on panel blinks very often and I can't lock the car, lift windows up and down and start engine. But audio and all lamps work.
I guess ecu is Siemens_SID_801_5WS40030B-T.
I'll clarify ecu and bsi numbers today.
Fuseau horaire GMT +1. Il est actuellement 17h14.
