Vieux 16/11/2012, 16h43
TAGRART
Avatar de TAGRART
TAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud of
Par défaut Portable Renault Dialogys 3.79 (Reup 08.22)
Portable Renault Dialogys 3.79 | 5.89 GB
Dialogys - an electronic version of the documentation for RENAULT and after sales car RENAULT, DACIA (only LOGAN and SANDERO).
Dialogys includes everything repair manuals and parts catalogs for all models of cars Renault, as well as tehnoty and MR-s for all cars in the Russian, except for vehicles up to 1996.
Extras. Info: Your attention is the portable version of the Renault Dialogys 3.79, is designed for those who do not work with the program continuously and only occasionally wants to see documentation. For these users, this can be a convenient option, which is placed on a dual-layer DVD9.
This version can be run directly from a DVD or copied to a local hard drive or flash. The package includes a condensed version java runtime, Acrobat Reader 7.0, the program itself, and the full version Dialogys documentation version 3.79 from 22.10.2009.
Feature of the portable version is that it does not require installation and does not make any changes to the file system or registry of the computer, with two exceptions documented in readme.txt.
This version has been tested on systems of Windows XP SP3, Windows 2000 SP1 and Windows 7 (x86). It is recommended to test the functionality of downloading a full portable version on your computer. To do this, download all the files except for the data Dialogys_3.79_20091022.dat (You can also delete the contents of folders and local ar5), and try to run Dialogys.exe. In the case of the logo of the system (without the data file menu does not appear - this is normal behavior), it should work in full after resuming the data file.
This distribution is a repacked version of the original distribution, but is laid out in portable form because of lack of interest in the above subject.
liens par MP
TAGRART est déconnecté   Réponse avec citation
The Following User Says Thank You to TAGRART For This Useful Post:
mohhizbar (27/11/2012)
