Vieux 25/12/2018, 12h33
tmm47
Avatar de tmm47
Pouvoir de réputation: 8
tmm47 has a spectacular aura abouttmm47 has a spectacular aura about
Salut, a voir
BMW 120d 2009 edc17cp02 egr off (OK)
Peugeot P406 edc15c2 egr off (OK)
Peugeot P407 edc16c34 egr off (OK)
Golf 6 PCR 2.1 egr off (OK)
Passat B6 EDC17CP20 dpf off (OK)
Citroen c4 1.6 hdi edc16c34 egr off (wrong solution)must use Peugeot (Solution 2)
Ford Galaxy 2.0 tdci SID206 egr off (OK)
Clio 1.5dci egr off (OK)
audi A3 with pcr 2.1 for dpf and worked perfectly.
suzuki 1.9 dpf ok
peugeot edc17c10 dpf ok
Audi a4 2.0 tdi edc16u31 egr off ok Tup
peugeot 308 edc16c34 dpf ok
volvo s60 edc16c34 version switch ok
Denso Mitsubishi DPF made more than 10 cars and no problem with Both Processor 7058 and 7059
Alfa 159 edc16c39 egr OK
Opel Zafira edc16c39 dpf OK
MB E320 w211 EDC16C2 DPF Type 1 don't work Type 2 DPF OFF ok.
Opel vivaro 1.9dci EDC15C2 Egr off ok with disconnected egr plug.
635d with edc16cp35 and works Very good with dtc off.
mazda 3 2007 1.6d edc16c34 dpf solution -OK
Audi A4 EDC17CP14 DPF Off
Audi Q7 EDC16CP34 DPF Off
VW Touareg EDC16CP34 V6 DPF Off
Renault Scenic EDC16C3 V1 DPF Off (How to know the version you need ? )
BMW 320D EDC16C35 DPF Off
Will test SID305 Renault next week.
BMW EDC16C35 DPF EGR OK
PEUGEOT DELPHI DCM3.5 DPF OK
AUDI A1 SIMOS PCR 2.1 EGR DPF OK
mazda5 2006 2,0 81kW DENSO dpf (OK) yea,all dtc erase
Passat ppd 1.2 2007 year dpf ok but cruise control stop working.Please any solution ?Do VCDS can not be activated again?
renault edc16C03/9 DPF OK
WV Transporter 2006 2,5 96kW EDC16U34 DPF Generic Switch (OK)
Opel Vectra 1,9DTi 16c39 dpf off= (OK)
Ford S-Max 2007 SID 206 EGR off= OK
Fiat 500 mjd8f2 DPF OK delete sensor
Fiat 500 mjd8f2 EGR OK
Fiat Bravo 2008 EDC16C39 EGR OK
307 SID 803 DPF ok with solution 803A
EGR Vectra edc16 - one switch OK
audi A4 2,0 edc 16u31 dpf off=OK
caddy 1.9 edc 16u34 egr/dpf off=ok
caddy 1.6 simos pcr 2.1 egr/dpf off=ok
Hyundai Santa Fe 2008 edc16c39 EGR OFF P0489 EGR Disconnect ---- delete ok DPF OFF error P2002 P0473 --- delete OK
ford visteon ecu egr off = good
pcr2.1 egr done ok
zafiza edc16c9 dpf ok
astra edc16c39 dpf off ok
Ford Galaxy 2008 SID206 DPF/EGR= OK
Citroen Jumpy 2.0hdi delphi dcm3.5 dpf off
VW Pasat 2.0tdi 170hp.siemens pdd1.2 dpf-OK
ford connect 2013 sid206 egr dpf off ok
laguna 2 1.9 dci edc16c3-9.21 type 1 for dpf and egr off.
DPF OFF PSA SID803 / SID803A yes no problem
SUZUKI EDC16C3 1.9 DDIS DPF OFF OK
ford KUGA delphi 3,5 dpf off. GOOD TESTED
mitsubishi denso dpf off ok
Peugeot 407 EDC16c34 FAP off......OK
Flap off mercedes c220 e mercedes classe B=ok
Passat cc edc17c46...egr off OK
Mazda 6, engine code RF, model year 2005: DPF OFF ok, no more regenerations, it seems all faults codes deleted by the software, because I disconnect maf and no mil light!
Ford Transit 2.2TDCI DCU101 - EGR off = Ok
EGR and DPF on fiat = Good
EGR and DPF on hyundai = Good
Ford delphi egr not ok
Hyundai Tucson 2.0 CRDI 4WD 2006
VOLVO S60 & XC90 EDC16 DPF OFF WORK OK
Focus 1.6 tdci EDC16C34 EGR OFF ok with DTC table patch.
in my case,VW Crafter EDC16CP34-4 DPF and EGR off,works OK...regards.
Ford Mondeo, year 2008, Siemens SID206, EGR OFF works ok!
Egr golf 5 edc16u1 1.9l 105cv bkc ok.
Audi A5 2.7tdi edc17cp14 dpf OK.
Citroen Xsara Picasso, year 2007, engine 9HZ, EDC16C34 egr off ok, I select peugeot -->EDC16C34 --> type 2 if dpf still on screen you need codding bsi & dash without dpf.
Mercedes W164 EDC16CP31 2MB flash - EGR_OFF_DTC 2527 2511 2355 OFF
Ford dcm3.5 kuga working OK dpf off
EGR OFF of BMW e90 320D 163hp 2006year EDC16C35
opel meriva a z13dtj dpf off works good.
opel corsa d z13dtj dpf off works good.
FLAPS OFF for Mercedes-Benz CLS 320CDI V6 224hp 2007year EDC16CP31
SIEMENS PCR 2.1 of Seat Ibiza 1.6TDI CR 105hp 2012year
EDC16C9 of Opel Astra H 1.9CDTI 150hp 2006year for FLAPS OFF and EGR OFF !!!
Mercedes-benz w221 s-class 320cdi v6 235hp 2008year EDC16CP36=>DPF OFF=OK !!!
Mercedes E320 w211 EDC16C2 DPF Type 2 - DPF OFF (OK)
Opel Zafira 1.9CDTI 120hp 2008year BOSCH EDC16C39-DPF OFF=OK .
Vw golf 6 2.0tdi 103kw 2010year BOSCH edc17c46-DPF OK; EGR NOT WORK .
Seat Ibiza 1.6CR TDI 105hp 2012year SIMOS PCR 2.1=>EGR OFF=OK !!!
Egr off in edc16c9 opel ok unplug actuator dtc P0400 present in diagnosis but no warning light on ...for me ok so
DPF OFF for Audi a6 3.0tdi 224hp work perfect and can unplug all sensors
DPF OFF for Audi q7 3.0tdi 233hp work perfect and can unplug all sensors
VW Golf 6 1.6 PCR 2.1 DPF ok.
Audi edc17cp14 dpf off ok.
BMW 320d e90 2006r 120kw EDC16c31-35 type 2 solution dpf off -ok
Clio 1.5 dci my2007 Delphi DDCR EGR off OK
Subaru Legacy Denso DS 2.0TD 150hp DPF OFF OK
---------- Post added at 13h33 ---------- Previous post was at 13h32 ----------
l'autre liste de ceux qui ne marchent pas:
Skoda Superb EDC17C46 EGR OFF not work.
Peugeot 307 EDC15C2 DPF Off ... not work !!!
ford transit connect 1.8tdci sid206 egr off completly wrong, car don't even start anymore
Egr off for audi q7 3.0tdi 233hp edc16cp34 not work !!!
passat edc16u34 egr off not work
Subaru Impreza Denso DS 2.0TD 150hp DPF OFF KO Engine run only 500rpm No error in diag
Mini EDC16C35 Fap & EGR wrong solution
bmw edc17cp41 dpf off not ok.
Renault edc16c36 dpf off not ok.
MB W203 C220 EDC16C2 DPF Version 2 ECU bricked.
BMW E60 EDC16CP35/C DPF BAD SOLUTION
VW Passat edc15 EGR off --- DON'T WORKING
Citroen C3 EDC17C10 Dpf off ---- DON'T WORKING
sid 807 psa 4M and sid 807 ford
DPF off VW T5 2,5TDI EDC16U34
DPF OFF of EDC16CP35 of BMW e60 530d 235hp 2007year
VW Sharan 2.0tdi EDC16U31 - EGR Not OK
VW Crafter EDC16C34 - DPF Not OK, EGR - OK.
Honda 2.2 dti Boscho- solution nooo good
Opel 17cdti Denso Ecu Astra H. Dont work
Astra J 17cdti Dont work. No more dtcs
Mercedes Delphi 3.5 DPF not OK. Car runs in modified limp mode, no DTC's but automatic transsmision shifting is affected, no kick down function and also shifting to early.
Mazda 5/2007/2,0/105KW DPF and EGR off= NO
SID 204 landrover 2.7 egr off dont work
bmw EDC16CP35 not work dtc always here, after driving 15 min , car saying DPF error first must do ash reset to zero with diag tool after write dpf off file ... without this 50% dpf off by bmw not work
PCR2.1 DPF off doesn't work. Gives an P2243 error No problem for me. I tried many CAYC without problem, just clear dtc.
psa edc15c2 not detected corekt switsch2 dpf off switsch1-ok
Vw crafter EDC16CP34-4 ,doesn't work DPF off
BMW e91 EDC17Co2 DPF off - not ok KILL CAR
opel astar h 1,9 diesel from 2007 egr off not works.edc16cp39
EGR and DPF on Daimler B180 edc16 not work (fault 2084). Regards
audi a3 2.0 tdi 103kw bkd edc16u egr off not work. after one day ligth on and error code p0401
DPF Remover for Insignia EDC17c19 no good
S320cdi edc16 not work., S420 cdi V8 not work. W204 CRD3 not work .Car limited on 3000 rpm , no DTC , in live data car ask EGR 5% , real time shows 0% .Both solutions DPF+EGR .
Passat cc edc17c46...DPF off. No Ok
jeep wrangler 177cv edc16cp31 "error dpf map not found"
Vw Crafter Edc16CP34 and Opel Insignia Edc17 Not working.
C4 PICASSO 2008 EDC16C34 not working
Citroen sid807 No Maps found
Vw Crafter edc16cp34 Solution not working. DPF paramenters reset before flashing.
Peugeot 807 EDC15C2 DPF Off= wrong solution P1429 failure.
audi A4 PPD 1.2 dpf don't work.... just remove dpf sensor and drive car for few Km
Skoda 2.0tdi 170hp siemans pdd1.2 ecu dpf not work,
DPF PSA EDC15 don't work
Opel Vivaro 2.5tdi edc16c36 dpf+egr off have appeared P0487 P0488 errors
Ford c max 2004 1.6tdci edc16 34. Egr of not working.
Fiat qubo 1.3 mjet 6f3 no good solution +1,5lt oil after 2 week
ford cmax sid 803a dpf off=NO
crafter edc16cp34 ecu bricked after write asc solution, had to recover with bdm
Vectra 1.9 EGR, check after 200km and P0400
ford 1.4tdci at Siemens sid804
Sprinter DPF after 200km regenration begin .. solution not good
vag simense pdd1.2 not ok light of dfp still on and if i remove airsensor cable not detected in diag
Nissan Micra DDCR egr off=not ok
mazda5 2007 105kw Denso dpf off= NO
Audi EDC 17C52-CP52 Switch- not working.
Citroen c4 picasso 1.6 edc16c34 EGR off = not work work for me with type 2
DPF solution on PSA EDC15C2 not work.
Egr off "EDC16U34 generic solution" on audi 2.0l TDI 140 NOT OK.Hysteresis are wrong and egr is active again.
mazda 3 2007 1.6d edc16c34 dpf solution dosn work....after 170kmh engine try stop Made a mazda 3 with ecu 0281011995 and no problem at all. 0281011 is electric intercooler bypass model, need to use ford edc16c34-2.20
FIAT EDC15C2 with Citroen Dpf remove solution : not ok
mazda 5 denso from 2007 not working. not dpf light,but car dont react to gas pedal.
PEUGEOT continental sid807evo NO DPF OFF
Kia edc15c7 egr wrong solution
egr off edc16c34 berlingo tepee . first version ,version 1 & 2 all not work
Hyundai/KIA EDC16C39 DPF OFF wrong solution
4,2 q7 edc17cp24. Doesn't work. Ecu stops responding. After checksums counting ecu doesn't work anyway.
Flaps remove on edc16c34 butt not working.
tmm47 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to tmm47 For This Useful Post:
DIAGSYSTEM25 (25/12/2018), jah83 (25/12/2018)
