Revo Uninstaller Pro 3.1.9 Multilingual + Portable
Revo Uninstaller – innovative uninstall utility. Uninstall, delete, remove programs and solve uninstalling problems. Revo Uninstaller helps you to uninstall and remove unwanted programs installed on your computer even if you have problems uninstalling and cannot uninstall them from “Windows Add or Remove Programs” control panel applet. Revo Uninstaller is a much faster and more powerful alternative to “Windows Add or Remove Programs” applet! With its advanced and fast algorithm, Revo Uninstaller analyzes an application’s data before uninstall and scans after you uninstall an application.
Here is the list of the tools and utilities included in Revo Uninstaller:
• Auto Start Manager – Stop programs that start automatically on Windows startup; speed up loading of Windows!
• Windows Tools Manager – Handy and useful tools bundled with every version of Windows; easily find useful system tools and options!
• Junk Files Cleaner – Find and remove unnecessary files from your computer; free up disk space and delete files you do not need!
• Browsers History Cleaner – Erase web browser history, visited pages history and temporary internet files of Internet Explorer, Firefox, Netscape and Opera web browsers; free up a lot of disk space by deleting temporary internet files like temporary saved videos, temporary flash files, temporary pictures etc!
• Office History Cleaner – Remove the history of most recently used files in MS Office; remove your tracks by deleting the list of last opened MS Office documents!
• Windows History Cleaner – Remove the history of recently opened files, delete temporary files, remove usage tracks and other history items that are saved by Windows; remove your tracks saved by Windows for a lot of operations!
• Unrecoverable Delete Tool – Erase files and folders forever; be sure that nobody could recover your files and folders after deleting!
• Evidence Remover – Make sure already deleted files, folders and other data are unrecoverable; securely erase your data!
Main Features of Revo Uninstaller Pro:
Uninstaller
The Uninstaller tool lists the installed programs and components for all and current user. With a choice of views, as well as a context menu, information on program components is available: program properties, their registry entries and links to manufacturer's web site, for a start. The "Search" option finds installed applications just by typing the first few letters of their name. Revo Uninstaller Pro scans for leftovers with even more advanced algorithms that are so precise, fast and very effective in search for leftovers of Windows Services, Drivers, File associations, Shell Extensions, COM components, Windows Installer components, program settings and more!
Forced Uninstall
Revo Uninstaller Pro has a very powerful feature called Forced Uninstall. This feature allows you to remove leftovers of programs that are already uninstalled, incomplete installations and uninstall remnants of programs! It does not matter if the program, you want to remove, is not listed in Revo Uninstaller Pro or in Windows Add/Remove Programs Control Panel applet. Forced Uninstall gives power to the user but still keeps the safety and the accuracy of the results. It is very useful when the installation is corrupted and cannot continue further. Forced Uninstall is the best solution when you have to remove partially installed programs, partially uninstalled programs, and programs not listed as installed at all.
Quick\Multiple Uninstall
Another way to uninstall a program with Revo Uninstaller Pro or few programs at once is to use the Quick Uninstall command. The sequence of actions is similar to the regular Uninstall command of Revo Uninstaller Pro, but when it comes to the step where you have to review and delete the leftovers, the Quick Uninstall operation deletes the leftovers automatically reporting to you the number of deleted leftovers; and in case you have selected more than one program for uninstall, automatically starts the uninstall of the next selected program.
Real-Time Installation Monitor
Revo Uninstaller Pro has a feature that allows monitoring of installation of a program. It detects system changes during that installation and the process is done in real time – simultaneously! Real-Time installation monitor is the most advanced and innovative technology used today! This technology is unique among the rest of the uninstallers. That is why it offers the easiest and the fastest way to monitor installations, so when the program is no longer needed the system changes made by the installation of the monitored program could be fully reverted as the program has never been installed before! It is so easy to use that requires only 3 mouse clicks to accomplish the whole process!
Logs Database
This is a database of logs of traced programs through the monitoring module of Revo Uninstaller Pro made and managed by Revo Uninstaller Pro's team. That logs are stored on our web server and you can easily (with one click only) use them to uninstall programs or to uninstall leftovers of already uninstalled program. Using a log from the Logs Database is the same as if you have made the log and traced the program by yourself. So, even installing Revo Uninstaller Pro on a fully loaded computer with a lot of installed programs, you can take an advantage of the possibility for better and complete uninstall using the logs from the Logs Database, as you only have to search for the program you want to uninstall and select Uninstall command.
Manage installation logs
You have a full control over the traced logs. You can edit their data and properties, export or import a log to your Revo Uninstaller Pro.The Edit command let you see all traced changes on hte file system and Registry. The Export and Import Log commands let you share logs with anybody using Revo Uninstaller Pro quite easily thus being sure you are doing the ultimate uninstall of the programs you have installed. For example, if you have problems uninstalling Program A or just want to do a better uninstall of Program A and a friend of yours has installed and traced the same program and has a log, he can just export the log and send it to you. You can import it and use it to uninstall the program as just as if you have traced it.
Multi-Level Backup System
Revo Uninstaller Pro creates backups of removed registry keys, values, files and folders. Backup Manager is the main part of that system. It helps you to manage backup information stored by Revo Uninstaller Pro after deletion registry entries, files and folders.
The other levels of the backup system are:
Creating system restore point before each uninstall
Full Registry backup before each uninstall
Full Registry backup once each day Revo Uninstaller Pro is started
Hunter Mode
This is a special, innovative feature of Revo uninstaller which gives you the flexibility to uninstall, stop or delete programs with one click only by simply dragging the Hunter window, with the mouse cursor, over desktop icons, quick launch toolbar, in the system tray or to the open program's window.
