CarProg reprogramation tokens
Salut tous le monde .
pour ceux qui veulent renouveler les token's de leur carprog ceci est possible des aujourd’hui testé et garantie avec même plusse d'options qu'il le faut .
efficacité prouvé avec tout ce qui est NEC... et les adaptation Mileage ...
ok-opel vivaro 2009 autoliv unit crasch clear works fine eeprom 95160
ok- Opel CDR 500 read pin code/serial thru OBD connector OK. (Only need to bridge pin 3 and 7 on A1 adapter as K-line is on pin 3.)
ok - Ford ecosport airbag crash erase diag - work
ok - Old kangoo dash with 908
NOT - 2004 Vectra C EDC16.Vin and mileage was ok but pin code was wrong
ok - corolla 1999 93c66 immo key adaptation work perfect (TABLE)
ok - SAAB 93 2008 9s12 works well
ok - airbag opel corsa 24 439 954 doing all ok but in auto not clired
ok - Fiat Ducato 2009 by OBD+A1 - correction successful.
ok - audi dash repair to two cars audi a3 with blinking lights problem.......success
ok - fiat punto 03 odo adjustment by obd.....success
ok - opel ecu hybrid corsa bosch m1.5.5 pin code read and reset by obd on table.....success
ok - renault megane scenic old 1997 model key pin code read and write.....success
ok - Panda by OBD - ok
ok - A4 RB4 obd - ok
ok - Espace read pin by obd ok
ok - Astra H read pin ECU by obd - ok
ok - Clio airbag hc12d60 by obd - ok
NOT - Peugeot 307 BSI 2004 95160 not work
ok - Audi A4(05) rb8 read/write dash by obd OK
ok - China cable EWS BMW - fix db25 pin 10 and 11
ok - Renault Laguna MKII - resincyng car key after some i***t tried to add another key and adding a new key- OK via OBD
NOT - Carprog ( original ) can't read SAAB PSG-16. I need get another to car, how I can make synch with immo?
ok - mercedes vito 2002, magneti mareli cluster via dash connectors, thro dashboard section, read OK, write OK. sw 4.86
NOT - dashboard ford focus 2008 not working , not read with carprog clone, A1+FORD+ 12V EXTERNAL CAN, NOT WORKING
ok - Ford Focus year 2006 low line dash worked alright, with only A1 adapter and no external power.
NOT - read km focus 2008 and does not work, has MC9S12XHZ512VAL
ok - i done ford fusion 2008 whit external power a1 cable no problem whitout power no work
OK - Skoda Fabia VW5 airbag with HC08 - diag is a NO GO, but still, I managed to clear it on the bench.
ok - vw polo 96c86 by v4.86 and reads fine
NOT - Tested A3 2005 for fun today, km read ok, write nothing....
ok - Ford S-Max, dashboard - Lo, 2008 year, Read-write as Galaxy
ok - Tested on Fiat Stilo 2003 (after backup eeprom with upa) - read/write OK.
ok - Tested on Focus 2005 (after backup with Smok Ford) - read/write ok
ok - 2007 Passat and octavia dash ok. ReadEEP/writeEEP/KM/decryptEEP all ok.
ok - Laguna 2004 threw dash connector - ok (im not sure, prapobly hc08 dash)
ok - Focus 2004 OBD - game over - had to reconnect battery/dash to reset cpu.
ok - Citroen Berlingo HC08, read and write OK.
ok - Fiat Punto by OBD2, read and write OK.
NOT - Fiat Stilo diesel 2005 dash ,read by OBD, km real, after write got ------ and Dash Error. Mcu 0L26M inside, 912D60 ver2 by NYO - Easy cured with Xprog and NYO4
NOT - Golf 5 Visteon with 95160 or 95320 NOT CAN, DO NOT TRY, KILL THE DASH !
ok - Z14XE work ok
ok - VITO 1999y Airback reset ok
ok - Audi A6 from 2005 to 2006 dash km change ok
ok - Opel Z14XEP(BOSCH 6.2.2) dont work
ok - 1.7 DELCO WORK ok
OK - mercedes vito 2001 motorola inside pin conetion working good carprog clone
ok - try carprog clone on ford fusion 08 plate by obd cable and plus ford cable NEED +12
ok - passat 2007 tdi with c.p,change km ok,read eeprom ok,the edc make wth other tool becouse in c.p 4,85 its n.a
ok - Astra-H 1.4l - ECU - Z14XEP (ME7.6.2) CAN, hibrid, PIN , mil , VIN - R/W OK, Reset ECU - OK
NOT - Passat 2007 with micronas 3297 24c32 V15.01,EEPROM read write not work ,KM change work not ,connected OK. IMMO only FF
NOT - Touran 2007 with micronas 3297 24c32 EEprom read write not work ,KM change work not ,connected Ok.IMMO no read.
NOT - Ford focus 2008 km change diag not work .
ok - Skoda Octavia 2007 OBD > OK
ok - Audi A4 RB4 2003 OBD > OK
ok - SRS VW 6Q0 909 605 C + CP + A15-adapter + external 12V to CP.
NOT - tested on ASTRA H ecu DELPHI MT35E . read km , vin and pincode.
ok - Audi A4 2005 Dash BOSCH RB8 change KM via OBD - Adapter A1 Working 100% Read EEPROM - Woring 100%
ok - Clear Crash Airbag Ford Mondeo 2006 via OBD - OK!
ok - Add Chip-Card Renault Laguna II 2002 - OK!
NOT - BMW Key maker - BAD!
NOT - MB Key maker - BAD!
ok - Read/write MCU HC12 - OK!
ok - Opel Delco 1.7L read via OBD - OK!
ok - grand punto 2008 with carprog via obd
ok - Audi A4 2004 RB4 CRYPTO dash
ok - seat ibiza airbag unit 6q0909605s worked ok
ok - peugeot 307 airbag unit 5wk42908 worked ok
ok - jetta 2007 and 2008 micronas obd2 success
Lieu Tiaret Ville , pour prendre rendez vous contactez par M.P
