Vieux 18/04/2016, 23h47
3atman
Avatar de 3atman
3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of
Par défaut Xentry DAS 05-06.2014_full_b1_s1_v1
telecharger Xentry DAS 05-06.2014_full_b1_s1_v1
DAS - Xentry 05.2014 Installed Image Dell E5500 D630 / 620, IBM Acronis
Here is an Xentry DAS image for a Dell E5500, which will work on Dell D630 / 620, IBM T40/T43, Pana. CF19 and many other laptops.
This is 05-06.2014 version. Tested and working
PLEASE READ THE FOLLOWING
The image was made with Acronis True Image 2014 boot cd, so use this to recover the image.
This was made on a basic Windows XP (SP3) install, no drivers are installed, you need to install the ones for your particular laptop.
The multiplexer type is set for for PART D (C3), but there is a bin folder for SDConnect (C4), which you can copy over. Look in F:\Programme\DAS\
To change to SDconnect, rename the bin folder (to bin_PartD ,for example) and then change the name of the folder "original bin" to bin
No keys are installed. (keys are unique to your laptop / PC)
Use the KEYGEN MHH (on desktop) for DAS key (remember to set a date)
Use the Xentry Developer.exe (also on desktop) for Xentry key
Adobe Acrobat and Virtual CloneDrive are installed.
Fixes have been applied for SDstartup, Xentry Blacklist and missing pictures.
WIS, EPC and Starfinder are not installed, to keep the torrent size low. All of these are easy to add.
The password for user STAR is the default, User$star2004
Type de fichier : zip Xentry DAS 05-06.2014_full_b1_s1_v1.tib.zip (51,5 Ko, 190 affichages)
3atman est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to 3atman For This Useful Post:
adcsytes (05/12/2023), benazze38 (15/06/2018), chipshop (10/11/2017), cristian89ra (28/03/2024), liilmrll (29/01/2023), mecanodiag93 (03/05/2016), Milkdelish (06/07/2022)
