Discussion: Drivers Autocom cdp+
Vieux 04/01/2015, 23h34
AZICO
Avatar de AZICO
AZICO will become famous soon enough
salut l ami,
y a pas grans chose qui tourne sur windows X64
je te conseille un bon vieu XP
par curiosité j ai fais une petite recherch pour savoir si delphi/autocom tourne sur X64
j ai trouvé ca sur un autre site
How to install Autocom delphi 2013.2 install on window 7 64bit system:
1. Download 2013 Release 2 Autocom Delphi 2.13.2.0 from delphi website:
http://europe.delphi-dso.com/downloa..._HeavyDuty.zip
2. Just Install it, free download 2013 R2 Autocom Delphi Keygen.
If you have CDP with 5digits sn chose DS150E
If you have CDP+ with 6 digits sn chose DS150E NEW VCI
when you install it, pls choose :
a-710-142 = cdp+ (ds150e new vci) cars
a-710-210 = cdp+ (ds150e new vci) trucks
SN: cars id truck
100251 FSBQQJWHDCWA HYSOGTLPCOVA
Turbo Charger DSDZGGLPOUEI TWFGOCEGVQEC
Diesel Max IYBDEABBITSD GCMBIJZLHQNT
Max Module RWXGPDKLVHFY SRTHQUDLVBWK
RTD Logger UPTGYKPMOSJO EPZBLPMOSJLC
GWM ZGALUCTPLXCO MVFKQPYJYVNL
GWM MAX RQITAXTPZYEY WFLBBDMRKLUV
Autocom delphi 2013.2 patch download:
download 2013 R2 Delphi autocom path file
3. After install copy from all you need patched main.exe
Auto CDP plus full set cdp+ with all connectors for cars trucks
autocom cdp plus
4. Close your INTERNET CONNECTION on window 7 64bit operation system.
5. Open Delphi enter your sn and key (you have HW KEY on archive)and start activation, a pop-up will appear,chose yes and save the xml file.
New Autocom CDP plus for cars trucks generic
6.Request the activated xml file
7. After you have your activated file, open Delphi, enter again sn and key,start activation, a pop-up will appear, this time chose NO,and open your activated file.
If you install 2013 release 2 delphi autocom on window 7 64bit OS.you will see the error above. Do not worry, close delphi and copy from patch 64 the ok files and now open it again.
Close Delphi, open internet connection and run it again. Go to Help->Check for Updates and let it update your files.
Notice: Once the update it's done, copy original files from patch delphi x64 to delphi install folder. you must do this step!
then do again steps 3,4 and 7.
1.) After install copy from all you need patched main.exe
2.) CLOSE YOUR INTERNET CONNECTION.
3.) Open Delphi, enter again sn and key,start activation, a pop-up will appear, this time chose NO,and open your activated file. and again you will have the same error, just ignore it.
8. Close 2013 R2 Delphi.
9. Copy from all you need patched x64 ok files to Delphi install folder and
Remark: If you don't want to update checks, just go to Delphi install folder, and rename wyUpdate to let's say wyUpdateXXX and the checks will stop.
AZICO est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to AZICO For This Useful Post:
myalami (05/02/2015), shooter-09 (05/01/2015)
