21/06/2009, 14h12 | #1 |
Pouvoir de réputation: 0 |
307 BSI need virgin dump
Hi,my friend i'm new in this forum,i'm glad to talk with you,i want replace bad bsi in peugeot 307 1,6HDI 2005 I have found used bsi and writed ST95128,with virgin file,but when i start pps insert vin,pin code,and it tell me:bsi can't start program,please help,me.thanks.
21/06/2009, 14h47 | #2 |
Fondateur
Pouvoir de réputation: 1321 |
maybe you are using bad virgin file.
Je ne donne pas d'aide en privé. |
21/06/2009, 17h00 | #4 |
Fondateur
i don't think that's virgin !
21/06/2009, 17h16 | #5 |
Hi again ,i have question for you,maybe you have a virgin dump for my BSI ,i have many software and dumps for exchange ,maybe you need somthing.Regards t77
21/06/2009, 17h18 | #6 |
Fondateur
no, beleive me i don't have for that model,
i check with others virgin dump and it appear like not ok !!! is just for that i told you that's not ok !
21/06/2009, 17h23 | #7 |
Ok thanks for quickly reply.Now i know thats i must search for good dumps .
Thank You. |
24/06/2009, 01h17 | #8 |
Pouvoir de réputation: 18 |
Hi !
Sorry but your dump remains not virgin The details refering to your dump : VIN : VF33HRHR 9310(x)187 & the PIN refering is : QC(x)T So, here you are what are you seeking for ! Pass on PM, Best regards! |
26/06/2009, 16h11 | #9 |
Thanks of lot Mrpromega for this dump i will be try use it.
26/06/2009, 16h24 | #10 |
Welcome
give us the result, Best regards ! |
10/08/2009, 23h38 | #11 |
Ok today I was programmed your dump of BSI and car started. This dump really work after configuration....Many thanx Mrpromega for help. U are GREAT.
Best Regards |
11/08/2009, 00h19 | #12 |
Welcome again
Best regards ... |
13/08/2009, 16h27 | #13 |
Hello, I have troubles with engine starting on Peugeot 307 2.0 HDI 66kW 90hp (DW10TD) 2002 year.
It seems that immo blocks engine. Can comebody help me with fixing ecu and bsi dumps? ECU: siemens 93c56 BSI: 912dg128 See original files in attachment. Dernière modification par msv81 ; 13/08/2009 à 16h32. |
14/08/2009, 07h04 | #14 |
Hello write more about what happens with BSI and ECU? Bsi is VALEO? ECU siemens number please.
Regards |
14/08/2009, 11h52 | #15 | |
I guess ecu is Siemens_SID_801_5WS40030B-T. I'll clarify ecu and bsi numbers today. Dernière modification par msv81 ; 14/08/2009 à 11h58. |
Ecu delphi virgin file | Amine-TE | Immobilizer dumps/solutions | 17 | 25/03/2015 11h19 |
Please virgin BSI file for 206 | peppery | Immobilizer dumps/solutions | 1 | 30/05/2009 19h10 |
